BS2 Rev. B Homework Board Not Working... --RESOLVED
I decided to make a simple multi-LED flasher circuit this morning with my BS2 that I have had for almost 2 years.· As I haven't had any issues before, I didn't think twice about whether it would work or not.· After building the circuit, I plugged it in to the computer using the exact same serial cable I used when I first got it, wrote the program, and selected·run.· It successfully compiled, but the·"No Basic Stamps Found" box appeared.·
Has anyone else experienced a similar problem, or am I just having really bad luck today?
Thanks.
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
Post Edited (Vaati) : 4/27/2009 5:54:30 PM GMT
Thanks.
1) Check your power supply voltage / source
2) Check your serial connection. Has your computer's I/O driver(s) changed? Is this a USB adapter that's worked with Stamps before?
It often helps sort things out if you remove or disconnect any circuitry you've added so you're dealing only with the Stamp itself and any board it's mounted on.
"Bad luck" is often due to making assumptions, rushing to try something out, forgetting other related things.
It works.· The problem was that the other end of the serial cable wasn't hooked up to the computer at all...·
That makes me wonder if my Propeller circuit wasn't messed up at all...· I will check that now.
Thanks.
