Haydon stepper motors
Howdy,
I have a stepper motor that I picked up and it says the following:
Haydon Switch and Instruments, Inc.
35402 5vdc 2.5w 15deg. rev.
Stepper Motor
Other markings on one side 8432 lot number??
Four wires: Blue,Green, Red, Black
I cannot find a data sheet on this stepper. Haydon representatives say that they
no longer have any information. Google search does not produce anything.
Anybody have a data sheet, wire diagram or any information??
Thanks.
Stepper Motor
Thanks.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The label evidently already tells that. With the voltage and wattage, we can figure the amperage, but we can not figure the holding or moving torque.
5 vdc at 2.5 watts:
The windings should be about 10 ohms each.
Which would require 1/2 amp per winding, so by their label (which may not be accurate) you will need at least 2 amps to drive the stepper. I find your better off doubling that amount. You do not want the stepper to pull your voltage down and sink your power supply.
I searched and the stepper is probably a 4 wire bipolar stepper motor. They work a little different than a unipolar.
Bipolars have two coils which pulse from positive to negative, like below:
www.sscnet.ucla.edu/geog/gessler/topics/steppers.htm
Check it out, this will help explain how it works.
that url didn't help much, but the next one will
www.tigoe.net/pcomp/code/category/code/arduinowiring/51
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Post Edited (James Long) : 4/26/2009 7:39:50 PM GMT
