PPDB - No Comm
I just got a PPDB and the Prop Tool says no prop chip found on any port.
·· I have been running a PropRPM and it works\ed fine.
Is there something I'm missing? When it is plugged in (mini USB) Device Mgr shows COM6 w/the FTDI driver.
Any
would be greatly appreciated.
Post Edited (BADHABIT) : 4/26/2009 4:14:37 PM GMT
Any
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
That's about all I can figure to do w/the terminal.
Post Edited (BADHABIT) : 4/26/2009 2:25:34 AM GMT
3.1415926535897932384....
Then put it back in the RPM
Then I·put the prop and RPM eeprom back in the ppdb and still nothing.
What's wierd is: the RPM program·should be running off the eeprom, but the difference between the factory ppdb and the RPM one I've been using is not observable.
You still haven't got your s/u to work yet V ?
Post Edited (BADHABIT) : 4/26/2009 3:06:40 AM GMT
i have too a ppdb
first the ppdb in the factory setup. -> no connection to the rs232 -Port
following steps:
1) starting the PropTool
2) connected the usb-port to the pc-usb-port
3) power on -> bigBlue-Led must be ON
4) the usb-leds should be blinking
3) on prop tool control is the comPort OK ->
if this OK
connect GroundPin on Left Up-side to the GND on the rightside down look on the schematicsi
testing the chipPins 0 - 27
if check Ok
Testing: RS232 as
on lower left side are rs232-pins p0 - p4 (form left to right
connect chipPin30 to p2 (TX)
connect chipPin31 to p4 (RX)
testing the rs232 with a serial-object z.b. fullSerialDuplex
at the ppdb no stuff is connected read the little docu and the schematics.
regards nomad
connect chipPin 30 to
When you first hook up the board did you have to do anything to get the usb connect to work?
to quote the obvius
did you install the FTDI-driver ?
a few times
1.. Switch USB cables. (cross check the cable)
2.. Switch USB ports. (You'd be surprised)
3.. Install the Propeller Tool on a friends computer and test.
What type of power connection are you using?
OBC
New to the Propeller?
No, I have not. I attempted to use the Serial to Propeller schematic from the Propeller Diagrams, Schematics, and Images page. There is a thread about the problem with my circuit as well. I am going to just get the Prop Plug though and worry about the seril circuit later.
Now did your PPDB come with a manual or booklet? If so, look in there for the troubleshooting info, and see if that'll help.
2 - tried that along with uninstalling/reinstalling ports
3 - tried that on 3 comps total
The Power is 9v 400Ma - attached is a shot f the power in and 3.3v out waveforms
I'm really starting to think something is wrong w/the effing thing. If it worked it should run the EEPROM program from the PropRPM that already has a prog on it, instead it makes no diff between a blank one.
yesterday <--
Post Edited (BADHABIT) : 4/26/2009 3:35:42 PM GMT
power-supply ; on the ppdb: -> the bigBlue must be go ON
>>> have you the propeller-chip correct install ??
board in the left side (on german sockel) is a sign (sockel - sign chip sign must be the same
o | o chip
sockel
regards nomad
in the booklet, is no troubleshooting info :-(
ragards nomad
BADHABIT: wrote
>Posted Yesterday 6:38 PM (GMT -7) Quote This PostIgnore Posts From BADHABIT.Alert An Admin About This Post.
>I just got a PPDB and the Prop Tool says no prop chop found on any port. skull I have been running a PropRPM and it works\ed fine.
>Any idea would be greatly appreciated.
> Post Edited (BADHABIT) : 4/26/2009 1:45:55 AM GMT
i think when you starting the ppbd and you see COM& is connected & the Blue Led on upper Left-Side in ON
it's ok the ppbd is then OK
BUT, you can't run a programm, then you make a test with the intern blue led on the rightside
1) chipGND to connect to the GND on lower right side
2) chipPin[noparse][[/noparse]0] to blueLedPing[noparse][[/noparse]0]
3) write a little programm
DIRA[noparse][[/noparse]0]~~ 'is output
outa[noparse][[/noparse]0] ~ ' set low
repeat
!outa[noparse][[/noparse]0] ' now should blinks
regards nomad
Prog loaded/verified on RPM
'' PPDB Test
'Program loaded to eeprom
con time=5_000_000
PUB Flash
dira[noparse][[/noparse]0] ~~
repeat
waitcnt(time+cnt)
Maybe you need to call Parallax tech support Monday and discuss this.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
I hate the non reg PSUs they give ridiculous volts on light loads and then those volts die back at the slightest hint of work to be done! (But then I can get my SMPSUs free)
I will be talking with them 2mro
Guess you could use it·for a water heater
--Steve
Post Edited (BADHABIT) : 4/27/2009 8:14:32 PM GMT
