PPDB - No Comm — Parallax Forums
PPDB - No Comm
BADHABITBADHABIT Posts: 138
edited 2009-04-26 18:27 in Propeller 1
I just got a PPDB and the Prop Tool says no prop chip found on any port. skull.gif·· I have been running a PropRPM and it works\ed fine.
Is there something I'm missing? When it is plugged in (mini USB) Device Mgr shows COM6 w/the FTDI driver.
Any idea.gif would be greatly appreciated.
Post Edited (BADHABIT) : 4/26/2009 4:14:37 PM GMT
    edited 2009-04-26 01:58
    can pst (parallax serial terminal) find the ppdb? This may be worth a try first.
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    · Search the Propeller forums (via Google)
  • BADHABITBADHABIT Posts: 138
    edited 2009-04-26 02:04
    From what I can tell, which is very little, the terminal is sending to the board, and maybe the chip. the tx radio bttn flashes when I type and the Rx LED flashes on the board.
    That's about all I can figure to do w/the terminal.
    Post Edited (BADHABIT) : 4/26/2009 2:25:34 AM GMT
  • VaatiVaati Posts: 712
    edited 2009-04-26 02:40
    Huh... Although I don't have a PPDB nor a fully functional Prop connection [noparse]:([/noparse] I would think that it would be a connection problem on the board. i.e.; the prop or the EEPROM isn't in just right... If I were you, I would check all your connections just to make sure...
    3.1415926535897932384....
    edited 2009-04-26 02:49
    I have quadruple checked and rechecked all pins. Then put it back in the RPM board(it worked), then pulled it out and back to the ppdb. Then I tried the eeprom from the RPM to use the prog from that, but nothing happens then either.
    Then I·put the prop and RPM eeprom back in the ppdb and still nothing.
    What's wierd is: the RPM program·should be running off the eeprom, but the difference between the factory ppdb and the RPM one I've been using is not observable.
    You still haven't got your s/u to work yet V ?
    Post Edited (BADHABIT) : 4/26/2009 3:06:40 AM GMT
    edited 2009-04-26 03:14
    Does anyone know how to use the RS-232 port to load on the PPDB?
  • nomadnomad Posts: 276
    edited 2009-04-26 07:11
    hi,
    i have too a ppdb
    first the ppdb in the factory setup. -> no connection to the rs232 -Port
    following steps:
    1) starting the PropTool
    2) connected the usb-port to the pc-usb-port
    3) power on -> bigBlue-Led must be ON
    4) the usb-leds should be blinking
    3) on prop tool control is the comPort OK ->
    if this OK
    connect GroundPin on Left Up-side to the GND on the rightside down look on the schematicsi
    testing the chipPins 0 - 27
    if check Ok
    Testing: RS232 as
    on lower left side are rs232-pins p0 - p4 (form left to right
    connect chipPin30 to p2 (TX)
    connect chipPin31 to p4 (RX)
    testing the rs232 with a serial-object z.b. fullSerialDuplex
    at the ppdb no stuff is connected read the little docu and the schematics.
    regards nomad
    connect chipPin 30 to
    edited 2009-04-26 07:29
    That's what I figured about rs232. But since that didn't work either I thought there may be a dift way to hook it up.
    When you first hook up the board did you have to do anything to get the usb connect to work?
    edited 2009-04-26 09:07
    hello,
    to quote the obvius
    did you install the FTDI-driver ?
    edited 2009-04-26 09:26
    yes Captain O
    a few times
    edited 2009-04-26 15:05
    Any chance we could get you to attempt any of the following and report back?
    1.. Switch USB cables. (cross check the cable)
    2.. Switch USB ports. (You'd be surprised)
    3.. Install the Propeller Tool on a friends computer and test.
    What type of power connection are you using?
    OBC
    New to the Propeller?
    edited 2009-04-26 15:21
    BADHABIT said...
    No, I have not. I attempted to use the Serial to Propeller schematic from the Propeller Diagrams, Schematics, and Images page. There is a thread about the problem with my circuit as well. I am going to just get the Prop Plug though and worry about the seril circuit later.
    Now did your PPDB come with a manual or booklet? If so, look in there for the troubleshooting info, and see if that'll help.
    edited 2009-04-26 15:24
    1 - tried that
    2 - tried that along with uninstalling/reinstalling ports
    3 - tried that on 3 comps total
    The Power is 9v 400Ma - attached is a shot f the power in and 3.3v out waveforms
    I'm really starting to think something is wrong w/the effing thing. If it worked it should run the EEPROM program from the PropRPM that already has a prog on it, instead it makes no diff between a blank one.
    yesterday <-- yeah.gif· <-- PPDB
    Post Edited (BADHABIT) : 4/26/2009 3:35:42 PM GMT
    hi,
    power-supply ; on the ppdb: -> the bigBlue must be go ON
    >>> have you the propeller-chip correct install ??
    board in the left side (on german sockel) is a sign (sockel - sign chip sign must be the same
    o | o chip
    sockel
    regards nomad
    edited 2009-04-26 15:28
    hi,
    in the booklet, is no troubleshooting info :-(
    ragards nomad
    edited 2009-04-26 15:37
    hi,
    BADHABIT: wrote
    >Posted Yesterday 6:38 PM (GMT -7) Quote This PostIgnore Posts From BADHABIT.Alert An Admin About This Post.
    >I just got a PPDB and the Prop Tool says no prop chop found on any port. skull I have been running a PropRPM and it works\ed fine.
    >Any idea would be greatly appreciated.
    > Post Edited (BADHABIT) : 4/26/2009 1:45:55 AM GMT
    i think when you starting the ppbd and you see COM& is connected & the Blue Led on upper Left-Side in ON
    it's ok the ppbd is then OK
    BUT, you can't run a programm, then you make a test with the intern blue led on the rightside
    1) chipGND to connect to the GND on lower right side
    2) chipPin[noparse][[/noparse]0] to blueLedPing[noparse][[/noparse]0]
    3) write a little programm
    DIRA[noparse][[/noparse]0]~~ 'is output
    outa[noparse][[/noparse]0] ~ ' set low
    repeat
    !outa[noparse][[/noparse]0] ' now should blinks
    regards nomad
    edited 2009-04-26 16:08
    No blinky
    Prog loaded/verified on RPM
    '' PPDB Test
    'Program loaded to eeprom
    con time=5_000_000
    PUB Flash
    dira[noparse][[/noparse]0] ~~
    repeat
    waitcnt(time+cnt)
    edited 2009-04-26 16:19
    Did you repair the power supply problem between the time you posted the waveforms and this mornings post?
    edited 2009-04-26 16:23
    I didn't know there was one. It's the same supply used w/RPM. Just thought it was interesting that the supply had that
  • jazzedjazzed Posts: 11,803
    edited 2009-04-26 16:24
    BADHABIT said...
    That's a sh***y waveform. What happens to it if you pull the Propeller off the board?
    Maybe you need to call Parallax tech support Monday and discuss this.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-04-26 16:34
    The PSU traces are not good. The Smile from the 9V side is to be expected ( if it is a non regulated "wall wart" ) but the 3.3V should never dip unless the reg runs out of headroom or is going into current limiting. Is that causing restarts endlessly?
    I hate the non reg PSUs they give ridiculous volts on light loads and then those volts die back at the slightest hint of work to be done! (But then I can get my SMPSUs free)
    edited 2009-04-26 16:39
    It is, but a flat line from a 9 volt btty doesn't change anything.
    I will be talking with them 2mro
    edited 2009-04-26 16:58
    The current limiting option would probably show itself by the language formed, after placing a finger on the reg.
    edited 2009-04-26 17:05
    Toby Seckshund said...
    freaked.gif Ouch!!
    --Steve
    ·It actually was the Power Supply. I guess that effed up waveform actually did have neg. consequences.
    Post Edited (BADHABIT) : 4/27/2009 8:14:32 PM GMT
