Prop 1 mark II with pipelining
Don't know if this has been discussed before or not so sorry if it has. But wouldn't it be nice if a mark 2 version of the current prop 1 could be designed with instruction pipelining so that each instruction takes 1 clock cycle instead of 4? No other changes (don't know about any changes needed for the hub) just 4 times faster! ie 80 MIPS per prop instead of 20 MIPS.
Would this be possible with the kind of die/process technology changes that would be needed?
The best thing would be if the current 40 pin DIL could still be used as well.
Ian Mitchell
www.research.utas.edu.au
Ian Mitchell
The Prop B (64 I/O version) design has been completed, so it is just a matter of getting silicon, if demand warranted it.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Chip is doing that in the Prop II. There are 4 simultaneous accesses to hub memory per clock cycle. One instruction fetch, two operand (S & D) fetch and one writeback. The instructions are pipelined, but the net effect is one cycle per instruction. Hub memory has read/write quad long access instructions.
Info on the counters and high speed serial interface between props (48MBps yes MBytes)
Listen to the webinar on the parallax site for the full info
Ian Mitchell
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
I don't remember any mention of the Prop 2 having an external address bus? Though if that is the case, then thats awesome
(PS: The 6502 and 6510 both came in DIP-40)
Chip talks about perhaps a 44 pin DIP. It is an internal 1.8V part. Parallax do not have the volume for multiple parts, although there will be it seems at least two package types, a DIP (with 32 I/O bonded) and a 100 pin quad of some kind.
JMH
