Prop 1 mark II with pipelining — Parallax Forums
IanMIanM Posts: 40
edited 2009-04-22 01:54 in Propeller 1
Don't know if this has been discussed before or not so sorry if it has. But wouldn't it be nice if a mark 2 version of the current prop 1 could be designed with instruction pipelining so that each instruction takes 1 clock cycle instead of 4? No other changes (don't know about any changes needed for the hub) just 4 times faster! ie 80 MIPS per prop instead of 20 MIPS.
Would this be possible with the kind of die/process technology changes that would be needed?
The best thing would be if the current 40 pin DIL could still be used as well.
Ian Mitchell
www.research.utas.edu.au
