Simple gameshow buzzer
We are working on a fairly simple project that has two game show buttons(pin 0 & 1)·which·when pressed, light up an LED(pin 2 & 3). We are trying to incorporate a buzzer to sound when one of the buttons·is pressed. We have the buzzer wired to pin 7 and ground. This is all wired on a Stamp microprocessor BS1-IC. We've got the lights working, but we can't seem to get the buzzer to work. Any ideas? Here is the program:
Start: Let b1=0
········ Let b2=0
········ Input 0
········ Input 1
········ Output 2
········ Low 2
········ Output 3
········ Low 3
········ Output 7
········ Low 7
Gameshow: Button 0,0,255,20,b1,0,Loop2
Win1: High 2
········ High 7
········ Goto Win1
Loop2: Button 0,0,255,20,b1,0,Nopress
Win2: High 3
········· High 7
········· Goto Win2
Nopress: Goto Gameshow
Start: Let b1=0
········ Let b2=0
········ Input 0
········ Input 1
········ Output 2
········ Low 2
········ Output 3
········ Low 3
········ Output 7
········ Low 7
Win1: High 2
········ High 7
········ Goto Win1
Win2: High 3
········· High 7
········· Goto Win2
Or, if its a true buzzer try driving it with a transistor.
Mike2545
This message sent to you on 100% recycled electrons.
Post Edited (Mike2545) : 4/20/2009 11:34:37 PM GMT
You can't use the FREQOUT command. It's only for the BS2 series.
@Nicky
You may one to take a look at Humanoido's Stamp One News here. It probably has what you're looking for.
It is a buzzer and not a speaker, right? You can hook it up to a DC source and it will make sound? Just checking...
How much current does it draw? The BS1 probably can't handle the amount of current required. You'll need to use a transistor in that case.
Post Edited (SRLM) : 4/20/2009 11:40:34 PM GMT
Mike2545
Can the SOUND command work with a buzzer? Or do you have to have a speaker? This is a school project due tomorrow so we are pretty much out of time...but this is driving us nuts trying to figure out why it won't work.
Thanks to you both!
Mike2545
No transistor is needed for a speaker with the Sound command.
Mike2545
