Simple gameshow buzzer — Parallax Forums
NickydogNickydog Posts: 4
edited 2009-04-21 01:01 in BASIC Stamp
We are working on a fairly simple project that has two game show buttons(pin 0 & 1)·which·when pressed, light up an LED(pin 2 & 3). We are trying to incorporate a buzzer to sound when one of the buttons·is pressed. We have the buzzer wired to pin 7 and ground. This is all wired on a Stamp microprocessor BS1-IC. We've got the lights working, but we can't seem to get the buzzer to work. Any ideas? Here is the program:
Start: Let b1=0
········ Let b2=0
········ Input 0
········ Input 1
········ Output 2
········ Low 2
········ Output 3
········ Low 3
········ Output 7
········ Low 7
Gameshow: Button 0,0,255,20,b1,0,Loop2
Win1: High 2
········ High 7
········ Goto Win1
Loop2: Button 0,0,255,20,b1,0,Nopress
Win2: High 3
········· High 7
········· Goto Win2
Nopress: Goto Gameshow
  • Mike2545Mike2545 Posts: 433
    edited 2009-04-20 23:29
    You could use a speaker and use the freqout command. You should also use a 10uf cap in series with pin 7 and the speaker.
    Or, if its a true buzzer try driving it with a transistor.
    Mike2545
    This message sent to you on 100% recycled electrons.
    Post Edited (Mike2545) : 4/20/2009 11:34:37 PM GMT
  • SRLMSRLM Posts: 5,045
    edited 2009-04-20 23:35
    @Mike
    You can't use the FREQOUT command. It's only for the BS2 series.
    @Nicky
    You may one to take a look at Humanoido's Stamp One News here. It probably has what you're looking for.
    It is a buzzer and not a speaker, right? You can hook it up to a DC source and it will make sound? Just checking...
    How much current does it draw? The BS1 probably can't handle the amount of current required. You'll need to use a transistor in that case.
    Post Edited (SRLM) : 4/20/2009 11:40:34 PM GMT
    edited 2009-04-20 23:37
    Oups, then use the SOUND command
    Mike2545
  • NickydogNickydog Posts: 4
    edited 2009-04-21 00:28
    @SRLM: It's definitely a buzzer. When we apply the battery terminals of a 9V battery directly to the wires of the buzzer it sounds. The buzzer is labeled 3-16VDC.
    Can the SOUND command work with a buzzer? Or do you have to have a speaker? This is a school project due tomorrow so we are pretty much out of time...but this is driving us nuts trying to figure out why it won't work.
    Thanks to you both!
    edited 2009-04-21 00:45
    The sound command will not work with a buzzer. You will need a transistor to drive the buzzer from the stamp pin.
    Mike2545
    edited 2009-04-21 00:52
    Is a transistor needed only if the Sound command is used or is it needed regardless (i.e., using High command)? Thanks.
    edited 2009-04-21 00:55
    Like this for a beeper with the pin going HIGH
    No transistor is needed for a speaker with the Sound command.
    Mike2545
    2338 x 1700 - 76K
    edited 2009-04-21 00:57
    The sound command will probably give odd results. You'll not need to use it, instead make the pin high (on) or low (off). And never mind on the transistor. I have one that I just measured(radio shack version) and it only draws 2 ma. Try adding some pause statements. That should slow down your program and give you time to hear things.
    Okay, thanks. I'll try the pause statements.
