Hitec 6channel mixing question?
I am planning on making a robot using the motor mount and wheel kit with position controller and hb-25 motor controller and want to use a hitec transmitter and want to know how to mix the signal?· I want to use the right stick to control the direction, up goes forward, to the left, turns left ect.· I can get it to go forward and reverse but any information on how to mix the signal with the 2nd channel to make it turn would be helpful.· thanks
Try this.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
'{$STAMP BS2}
'{$PBASIC 2.5}
FWD_ESC PIN 15
Turn_ESC PIN 14
whl VAR Word
thr VAR Word
selector VAR Word
FREQOUT 4,1000,4500
'GOTO U_turn
mode:
RC:
PULSIN 10,1,selector
IF selector >750 THEN rc2
PULSIN 12,1,whl
PULSIN 11,1,thr
DEBUG DEC whl, " whl ", DEC thr, " thr ",CR
PULSOUT 15,whl
PULSOUT 14,thr
PAUSE 20
GOTO RC
rc2:
PULSIN 12,1, thr
PULSIN 11,1, whl
DEBUG DEC whl," & ",DEC thr,CR
IF whl >= 900 AND thr >= 900 THEN lt
IF whl >= 900 AND thr >= 700 THEN tl
IF whl >= 900 AND thr >= 500 THEN rtr
IF whl >= 700 AND thr >= 900 THEN forr
IF whl >= 700 AND thr >= 700 THEN stopp
IF whl >= 700 AND thr >= 500 THEN revv
IF whl >= 500 AND thr >= 900 THEN rt
IF whl >= 500 AND thr >= 700 THEN tr
IF whl >= 500 AND thr >= 500 THEN ltr
forr:
DEBUG " forward "
PULSOUT FWD_ESC,1000
PULSOUT Turn_ESC,750
PAUSE 5
GOTO mode
revv:
DEBUG " reverse "
PULSOUT FWD_ESC,500
PAUSE 5
'RETURN
GOTO mode
tr:
DEBUG " turn_right "
PULSOUT FWD_ESC,750
PULSOUT Turn_ESC,500
PAUSE 5
GOTO mode
rt:
DEBUG " right_tick "
PAUSE 5
GOTO mode
lt:
DEBUG " left_tick "
PULSOUT Turn_ESC,1000
PAUSE 5
GOTO mode
tl:
DEBUG " turn_left "
PULSOUT FWD_ESC,750
PAUSE 5
GOTO mode
rtr:
DEBUG " rtr "
PULSOUT FWD_ESC,500
PAUSE 5
GOTO mode
ltr:
DEBUG " ltr "
PULSOUT FWD_ESC,500
PAUSE 5
GOTO mode
spin:
DEBUG " spin "
PULSOUT FWD_ESC,750
PAUSE 500
RETURN
GOTO mode
slow:
DEBUG " slow "
PULSOUT FWD_ESC,890
PAUSE 5
GOTO mode
slow_R:
DEBUG " slow_R "
PULSOUT FWD_ESC,600
PAUSE 5
GOTO mode
aux1:
aux2:
aux3:
aux4:
aux5:
U_turn:
DEBUG " U_turn "
GOSUB revv
PAUSE 2000
GOSUB spin
PAUSE 2000
GOTO stopp
GOTO mode
aux6:
aux7:
'FREQOUT 4, 500,5432
GOTO mode
stopp:
'DEBUG " stop "
PULSOUT FWD_ESC,750
PAUSE 5
'RETURN
GOTO mode
