Questions To Chip on Prop 2? — Parallax Forums
SapiehaSapieha Posts: 2,964
edited 2009-04-18 15:16 in Propeller 1
Hi Chip.
I have questions on Prop2 functions You implements:
1. Many TFT VGA Displays wil have Clock pulse on every pixel.
? Is it posible to You implement this.
2. In Prop1 You have only fast IO output mode.
? It is posible to have TriState mode with RD/WR signals from Prop2
. Model:
. After DIRx Port is in TRiState.
. If I read (8 else 16 bit wide) from it .. It simply read Port with siglanling on one RD pin
. if I Write to Port (8 else 16 bit wide) It output to Port and signaling on WR pin
. To that it must be posible to dedicate (8 else 16 bit wide) Port As Tristate and 2 Pins as RD/WR
Ps. Have more questions
But them can wait
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Post Edited (Sapieha) : 4/18/2009 5:23:18 AM GMT
  • cgraceycgracey Posts: 14,289
    edited 2009-04-18 05:43
    Sapieha said...
    Hi Chip.
    This is possible. What is the relationship between the clock signal and data bits, though (setup times, clock polarity, etc.)?
    . Model:
    ·These things are possible, but could you elaborate on what other signals would be needed to complete this scheme (like a clock signal)?
    But them can wait
    Chip Gracey
  • SapiehaSapieha Posts: 2,964
    edited 2009-04-18 05:45
    Hi Chip.
    Yes I can elaborate on both poroblems.
    Tomorrow I wil post Timing on it.
    Sapieha
    edited 2009-04-18 07:25
    Hi Chip.
    Pictures HX8218-A.jpg and LTA070B0N0A.jpg is timings on TFT LCDs on RGB Clock
    Tristate IO timings is for easy implementing SRAM/IO BUS structures with not ned to switch DIRx for every Read/Write cycle
    It is (8 else 16 bit wide) BUS and 2 RD/WR pins.
    For flexiblity it is desired to have posiblity to direct RD/RW to any PIN pair on Prop2 in and of 32 Pins group
    Ps. Clock frequencies on TFT RGB DOTs is same as DOT frequencies on VGA Displays
    Ps 2.· I forgot to say that RD/WR signals must have posiblites to have programable Wait states
    Sapieha
    Post Edited (Sapieha) : 4/18/2009 8:03:52 AM GMT
    1057 x 510 - 56K
    921 x 1022 - 109K
    1049 x 774 - 80K
    967 x 622 - 64K
    edited 2009-04-18 12:37
    I don't mean to intrude on your post but I have wondered if the prop 2 is going to be able to use an SD card or other mass storage device as
    program storage. I saw the webinar video and it sounded like this was what you where saying. It would be a HUGE feature that I would be
    looking forward to.
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontrolled.
    edited 2009-04-18 14:56
    SD is 1/4 bits wide and far too slow to "run" code in; it is only useful for file storage.
    microcontrolled said...
    looking forward to.
    www.mikronauts.com - a new blog about microcontrollers
    edited 2009-04-18 14:59
    Exposing the pixel clock, ideally active only during "visible" pixels, would allow feeding TFT and older STN etc panels easily from a Prop.
    Exposing the "LATCH INPUT" as a "~RD" and "LATCH OUTPUT" as "~WR" would allow for fast interfacing to memory, as well as D/A converters etc.
    Both would be very good things [noparse]:)[/noparse]
    Chip Gracey (Parallax) said...
    Sapieha said...
    </P>
    . Model:
    But them can wait
    </FONT>
    edited 2009-04-18 15:12
    Sapieha, great idea. Looking at the timing and signals I wonder if it would be possible to combine the video/ram/I/O into a single subsystem. The output to the TFT looks very similar to the I/O and memory write timings. The read timings are also similar, the major difference being the data direction and having the data available earlier.
  • AleAle Posts: 2,363
    Sapieha: The ahem, xmos chip, can do most of what you want. Its port hardware is quite versatile (I wish the prop had something like that!). Sadly it only comes in BGA unfriendly packages :-(
    Edit: I do not know about the timing but if they keep adding stuff (because we ask for it!) it will be taped-out in 2020 freaked.gif We need (want want want) it now roll.gif
