Questions To Chip on Prop 2?
Sapieha
Hi Chip.
I have questions on Prop2 functions You implements:
1. Many TFT VGA Displays wil have Clock pulse on every pixel.
? Is it posible to You implement this.
2. In Prop1 You have only fast IO output mode.
? It is posible to have TriState mode with RD/WR signals from Prop2
. Model:
. After DIRx Port is in TRiState.
. If I read (8 else 16 bit wide) from it .. It simply read Port with siglanling on one RD pin
. if I Write to Port (8 else 16 bit wide) It output to Port and signaling on WR pin
. To that it must be posible to dedicate (8 else 16 bit wide) Port As Tristate and 2 Pins as RD/WR
Ps. Have more questions
But them can wait
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Post Edited (Sapieha) : 4/18/2009 5:23:18 AM GMT
Chip Gracey
Yes I can elaborate on both poroblems.
Tomorrow I wil post Timing on it.
Sapieha
Pictures HX8218-A.jpg and LTA070B0N0A.jpg is timings on TFT LCDs on RGB Clock
Tristate IO timings is for easy implementing SRAM/IO BUS structures with not ned to switch DIRx for every Read/Write cycle
It is (8 else 16 bit wide) BUS and 2 RD/WR pins.
For flexiblity it is desired to have posiblity to direct RD/RW to any PIN pair on Prop2 in and of 32 Pins group
Ps. Clock frequencies on TFT RGB DOTs is same as DOT frequencies on VGA Displays
Ps 2.· I forgot to say that RD/WR signals must have posiblites to have programable Wait states
Sapieha
Post Edited (Sapieha) : 4/18/2009 8:03:52 AM GMT
program storage. I saw the webinar video and it sounded like this was what you where saying. It would be a HUGE feature that I would be
looking forward to.
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
www.mikronauts.com - a new blog about microcontrollers
Exposing the "LATCH INPUT" as a "~RD" and "LATCH OUTPUT" as "~WR" would allow for fast interfacing to memory, as well as D/A converters etc.
Both would be very good things [noparse]:)[/noparse]
Edit: I do not know about the timing but if they keep adding stuff (because we ask for it!) it will be taped-out in 2020
