Rs-485
Hi,
Do we have a way to read RS-485 communications with a Javelin?
I have a device which is emiting data that I want to retreive on my Javelin and store on an USB Key. 24/7.
JM
JM
What protocol does the device use? RS-485 doesn’t imply anything other than the signal type/level. How the data is communicated (protocol) could vary from device to device. Assuming it uses standard serial protocol then you could interface to it with a MAX-485 type driver and receive the data. If it is a network device using TCP/IP, UDP or some other network protocol then you’re going to have a more difficult time.
Chris Savage
Parallax Engineering
Thanks for your reply.
The device I'm trying to attach documentation is attached to this post. I think that it's a "simple" serial communication because they say that we can connect it directly to the PC COM port and read the data. Do you know where I can find a schema for the MAX-485?
JM
The following link provides some standard RS-485/422 interface ICs that may work in your application. I hope this helps. Take care.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1111
Chris Savage
Here is a class that extends the Uart class for half duplex RS485.
Notice the parameter parity. If you don't need parity remove
the parameter. Best to create a new class in that case.
The class goes into folder ...\lib\stamp\core
regards peter
I will buy a MAX-485 or MAX-487 this week-end to start testing.
JM
