Rs-485 — Parallax Forums
Rs-485
jmspaggijmspaggi Posts: 629
edited 2009-04-16 12:10 in General Discussion
Do we have a way to read RS-485 communications with a Javelin?
I have a device which is emiting data that I want to retreive on my Javelin and store on an USB Key. 24/7.
JM
    edited 2009-04-15 16:59
    JM,
    What protocol does the device use? RS-485 doesn’t imply anything other than the signal type/level. How the data is communicated (protocol) could vary from device to device. Assuming it uses standard serial protocol then you could interface to it with a MAX-485 type driver and receive the data. If it is a network device using TCP/IP, UDP or some other network protocol then you’re going to have a more difficult time.
    Parallax Engineering
  • jmspaggijmspaggi Posts: 629
    edited 2009-04-15 17:06
    Hi Chris,
    Thanks for your reply.
    The device I'm trying to attach documentation is attached to this post. I think that it's a "simple" serial communication because they say that we can connect it directly to the PC COM port and read the data. Do you know where I can find a schema for the MAX-485?
    JM
    edited 2009-04-15 19:16
    JM,
    The following link provides some standard RS-485/422 interface ICs that may work in your application. I hope this helps. Take care.
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1111
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-04-16 08:37
    JM,
    Here is a class that extends the Uart class for half duplex RS485.
    Notice the parameter parity. If you don't need parity remove
    the parameter. Best to create a new class in that case.
    The class goes into folder ...\lib\stamp\core
    regards peter
    Will be very usefull! Thanks a lot!
    I will buy a MAX-485 or MAX-487 this week-end to start testing.
    JM
