BoeBot with BS2, What are the limitations?
What are the limitatioms of a BS2 stamp when using it on a BoeBot or any other application for that matter? In other words, how many processes could be done? I want to combine the "Whiskers", Photoresistors and the IR sensors to all work in conjunction with each other.Is this possible, or will it overload? If there are 15 I/O's, can I use all of them for different tasks, such as controlling 4 servos while also controlling all the sensors, playing sounds and blinking LED's?
http://forums.parallax.com/showthread.php?p=741023
BTW, there are 16 I/Os on the BS2 (0 - 15).
The BASIC Stamp series are single thread operator controllers; which means they can handle one task at a time. However, the BASIC Stamp 2 has an execution speed of about 4,000 instructions per second; which means you can do task, such as a pulse to a servo, and you have 20 ms of free time before the servo needs another pulse. That means you can check sensors, such as the whiskers or IR modules that you have on the Boe-Bot. As SRLM stated, it really depends on the program and how it is written. You can also post the program you have, and ask for tips on condensing or making it more efficient.
I hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
