HOME BASE/Battery Recharger — Parallax Forums
morris4019morris4019 Posts: 145
edited 2009-04-14 21:20 in Robotics
I am going to make a kind of home base, that will eventually be topped with a IR Beacon. For now, I need it to recharge a very small 3v battery (about the size of a dime). Anyway, I have found this circuit for a charger using a wall transformer. My question is, I would like this home base to be mobile, without cords, for free movement all the way around it. Can I just replace the corded wall transformer with say a 9v battery?
-Mike
······ I'll try everything once [noparse]:)[/noparse]
    edited 2009-04-14 19:25
    Probably not. you need better control of the charging rate and some "smarts" if you are charging nimh or li-anything type batteries.
    - Stephen
    Franlin is right. You need to control the charging current. That circuit you posted would either fry the wall wart, the diode, or the battery. Once you have a charge control circuit however there is no reason it could not be powered by another battery.
