FullDuplexSerial Multi Channel
Hi, I am looking for a single FullDuplexSerial object (code) that can handle multiple channels (each with separate Rx,Tx,Baud and Mode). I could not find any such in ObEx. The versions available can handle only one channel per object/cog. I figured the number of cogs used is high with them. Do you know of any??
I know multichannels reduces the·baudrate since only one cog is handling all channels.
Please enlighten me if I am missing anything else, particularly if there is any data loss.
How much incoming data each prop pin can save in the internal buffer (if any).
Sincerely,
Venkata.
Sincerely,
Venkata.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The obx url is http://obex.parallax.com/objects/340/
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
Post Edited (Earl Foster) : 4/13/2009 5:42:38 PM GMT
Sincerely,
Venkata.
you can do 4 channels per Cog
so this gives you 16 channels on 32 IO-Pins in 4 cogs
best regards
Stefan
