FullDuplexSerial Multi Channel — Parallax Forums
VGVG Posts: 32
edited 2009-04-14 06:54 in Propeller 1
Hi, I am looking for a single FullDuplexSerial object (code) that can handle multiple channels (each with separate Rx,Tx,Baud and Mode). I could not find any such in ObEx. The versions available can handle only one channel per object/cog. I figured the number of cogs used is high with them. Do you know of any??
I know multichannels reduces the·baudrate since only one cog is handling all channels.
Please enlighten me if I am missing anything else, particularly if there is any data loss.
How much incoming data each prop pin can save in the internal buffer (if any).
Sincerely,
Venkata.
  • LeonLeon Posts: 7,620
    edited 2009-04-13 17:31
    How many channels?
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Earl FosterEarl Foster Posts: 185
    edited 2009-04-13 17:35
    There is a 4 port serial object written by Tim Moore that is available.· You might want to look into.· I have not used it myself but ... it is attached
    The obx url is http://obex.parallax.com/objects/340/
    WWW.HAPB.NET
    "Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
    Post Edited (Earl Foster) : 4/13/2009 5:42:38 PM GMT
  • Jay KickliterJay Kickliter Posts: 446
    edited 2009-04-13 17:45
    The 4 port serial object Earl mentions works great. I use it exclusively, even when I need only 1 serial line.
  • VGVG Posts: 32
    edited 2009-04-13 19:44
    Wow. That's quick and thanks a lot Earl. I will test it right now. I was originally looking for 16 channels. 4 is enough·for my project.
    Sincerely,
    Venkata.
    Hello VG,
    you can do 4 channels per Cog
    so this gives you 16 channels on 32 IO-Pins in 4 cogs
    best regards
    Stefan
