BitTorrent a possibility?
tonyp12
The ethics aside and that some routers and NAS's now have built-in BitTorrents
It would be cool to have·dedicated BitTorrent with a Propeller + WIZ812MJ + 4GB SDcard
Someone would need to write a basic torrent program for the propeller, think·µTorrent
You can let the PropTorrent download overnight with very little electricity use.
I am not knocking your idea I just don't understand it, why would a prop be a good idea for a P2P? again please don't take this the wrong way I just like to try and build some of the projects, well most of them that I can get my hands on
and if this is some good way to share files that I am not getting I would like to understand could you please elaborate?
You can turn your computer off (saving electricity)
As my idea is to use a 4GB SD card to save the files on,
you would log in to the PropTorrent and move them over to your regular Hardrive when done
and then select a one or two new torrents to download.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Have the torrent Client download torrents of a personalized RSS feed, so that you can add torrents to it from any computer. Now if you could combine this with a VLC like application and a VGA/composite output you might have one of the most wildly usable project on this forum.
should implement pg2 also
www.atmel.com/dyn/products/tools_card.asp?tool_id=4102
It has everything you need out-of-the-box and SD card socket. It comes preinstalled with linux. I have one from its cousins very powerful. It runs at 140 MHz some 32 or 64 MB SDRAM.
While it may be possible to support bittorrent with the propeller using an ENC28J60 and some already available software, the bt part you will have to write it yourself, beyond the "I can do it" I do not see the benefit. But if it is your thing, go ahead, the prop amazes us everyday (have you seen Linus demo yet ? no ?, get it!).
Ale
So it would be a dedicated "Box" for lack of a better term for automatically downloading all the content in a given parameter whenever the"box detects it?? I understand the protocol to be P2P but trying to get my hands around application would this be
analogous to nexislexsis?
