Online retailers?
Does anyone know where i can find a low voltage(6-12v) hi torque servo motor for 30 40bucks?
Im trying to rotate a shaft from one end,·it wieghs about 15 lbs. Speed is not an issue but id still like to keep the ration pretty low.
Ive search Lynx, Digikey, Robot shop, and a few others. Any suggestions?
Thanks in advance
Thanks in advance
- Stephen
http://www.robotmarketplace.com/products/servos_robot.html
http://www.servocity.com/index.html
About 180degrees of motion at most, unsure of the speed, that shaft is suspendin. Im actually trying to emulate a human waist/hip/leg to give you an idea.
thanks again
May I suggest the HB-25 motor controller. This device will power a large DC motor "1/2 HP" with common servo commands. this unit can simulate a servo motor if a gear reduction is used, like a worm gear drive.
Take a look at the HB-25
www.parallax.com/detail.asp?product_id=29144
_______$WMc%_____
The Truth is out there············································ BoogerWoods, FL. USA
Chris Savage
Parallax Engineering
