Online retailers? — Parallax Forums
Online retailers?
NoNo Posts: 26
edited 2009-04-08 17:40 in BASIC Stamp
Does anyone know where i can find a low voltage(6-12v) hi torque servo motor for 30 40bucks?
Im trying to rotate a shaft from one end,·it wieghs about 15 lbs. Speed is not an issue but id still like to keep the ration pretty low.
Ive search Lynx, Digikey, Robot shop, and a few others. Any suggestions?
Thanks in advance
    edited 2009-04-08 01:06
    Could you give more info? how fast, how many degrees rotation, is the shaft supported at the other end? Things like that.
    - Stephen
  • NoNo Posts: 26
    edited 2009-04-08 01:36
    Thanks for replying.
    About 180degrees of motion at most, unsure of the speed, that shaft is suspendin. Im actually trying to emulate a human waist/hip/leg to give you an idea.
    thanks again
  • $WMc%$WMc% Posts: 1,884
    edited 2009-04-08 03:38
    No
    May I suggest the HB-25 motor controller. This device will power a large DC motor "1/2 HP" with common servo commands. this unit can simulate a servo motor if a gear reduction is used, like a worm gear drive.
    Take a look at the HB-25
    www.parallax.com/detail.asp?product_id=29144
    _______$WMc%_____
    The Truth is out there············································ BoogerWoods, FL. USA
  • SRLMSRLM Posts: 5,045
    edited 2009-04-08 05:21
    Note though that if you use the HB-25 you won't get accurate positioning (like a true servo).
    Is this for BASIC Stamp control? A general parts question should be in the Sandbox Forum.
    Parallax Engineering
