BS2e Max. Current Consumption
Hello All,
I'm trying to calculate the Max. Power consumption I will use and the voltage regulator needed. I have all the Data Sheets for the parts I'm using (DS1302,shift register, BackLight Display...etc) that show ratings, but I could not find Current Consumption on the 20 MHz SMT part and the BS2e(Interpreter)SMT. The BS2e would be the main one needed. I've purchased a 5vdc 1.5a SMT regulator which appears to be way over the rule of thumb double the amounted needed....Anyway
1) I can not find the Max. Current of the BS2e?
2) 20 MHz Resonator...Is there much current draw at all???
thanks all
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks all
hmlittle59
The actual current drawn depends a lot on what's connected to the Stamp, but this is a good starting point.
The resonator does not draw power by itself. It uses energy supplied by the Stamp's oscillator to work.
I was trying to get it for the interpreter itself(I mixed up what I was asking for...My bad) but I will use these figures and see what I come up with. So far its 505 mA (max.). (8 I/O x 60 mA + 25 mA).
thanks again
hmlittle59
Post Edited (hmlittle59) : 4/6/2009 5:49:39 AM GMT
