<Newbie> Program an H Bridge
IS there a way to Program an H Bridge into the Prop ?
Daniel Mueth
"Just plug it in and let's see what happens"
Daniel Mueth
Post Edited (TChapman) : 4/6/2009 3:50:31 AM GMT
As using the Propeller as an H-bridge, you COULD do this, however, you should not try it with anything that will pull a significant amount of current. I can't remember off the top of my head, but I think the MAXIMUM current and I/O pin can source/sink is something like 40mA. You could write some code that would toggle two pins high or low, and attach a VERY small load in between. Maybe a couple of anti-parallel LEDs or something(with resistors of course).
Can you elaborate a little more on what you want to do?
http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/CategoryID/35/List/0/Level/a/ProductID/64/Default.aspx?SortField=ProductName%2cProductName
Building an H-Bridge is an art. My vote use what already works great.
TJ
I owe everyone here a bunch, So thanks again for answering my dumb questions.
Projects. RG500 ECU system. PropCopter. Prop CanSat. Prop Paste Gun.
Suzuki RG500 in a RGV 250 frame.
Bimota V-Due (Running on the fuel injection system)
Aprilia RS250
It's a bit expensive to buy 6x HB-26 for $50 each.
Edit:
One LM298 can control 2 motors.
60V / 2A max
