<Newbie> Program an H Bridge — Parallax Forums
samsn4samsn4 Posts: 49
edited 2009-04-06 15:55 in Propeller 1
IS there a way to Program an H Bridge into the Prop ?
Daniel Mueth
"Just plug it in and let's see what happens"
  • T ChapT Chap Posts: 4,260
    edited 2009-04-06 03:45
    You mean use the Prop pins as the Hbridge or drive an Hbridge via the Prop? You can program/drive transistors/Fets from the Prop, sure. Ideally an Hbridge driver IC would be used though for a number of reasons.
    Post Edited (TChapman) : 4/6/2009 3:50:31 AM GMT
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-04-06 04:14
    Daniel, you need to elaborate more on what you want to know. An H-bridge is simple a CIRCUIT that can reverse polarity to a load. You can write some code to control an H-bridge, but the circuit itself cannot be programmed. There are devices that can take digital logic in, or a servo pulse in, and control an H-bridge that way.
    As using the Propeller as an H-bridge, you COULD do this, however, you should not try it with anything that will pull a significant amount of current. I can't remember off the top of my head, but I think the MAXIMUM current and I/O pin can source/sink is something like 40mA. You could write some code that would toggle two pins high or low, and attach a VERY small load in between. Maybe a couple of anti-parallel LEDs or something(with resistors of course).
    Can you elaborate a little more on what you want to do?
  • TJHJTJHJ Posts: 243
    edited 2009-04-06 15:27
    If its a good· sized motor jus get this.
    http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/CategoryID/35/List/0/Level/a/ProductID/64/Default.aspx?SortField=ProductName%2cProductName
    Building an H-Bridge is an art. My vote use what already works great.
    TJ
    I owe everyone here a bunch, So thanks again for answering my dumb questions.
    Projects. RG500 ECU system. PropCopter. Prop CanSat. Prop Paste Gun.
    Suzuki RG500 in a RGV 250 frame.
    Bimota V-Due (Running on the fuel injection system)
    Aprilia RS250
  • Robot FreakRobot Freak Posts: 168
    I used a LM298 because I needed 6 motors.
    It's a bit expensive to buy 6x HB-26 for $50 each.
    Edit:
    One LM298 can control 2 motors.
    60V / 2A max
