Power problems
I have a 7.5 v 1amp power supply that I purchased for Parallax. I am running a ping sensor, three servos and a two line lcd.
The lcd flickers and goes out. Tech support suggested a larger capacitor (I am on a breadboard). I changed to a 2200 mf from the
1000 mf cap at the five volt output. The lcd continues to flicker. One servo is a standard that is panning. The other two are simulating
a tracked robot's motion. When the tracked simulation changes direction the change in current cuts out the lcd entirely.
According to my calculations and going over them with the support staff, I should not have a problem with power.
Any ideas?
Any ideas?
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
I do have this 1F cap very fun to play with
sorry to get off subject
How much?
Post Edited (mctrivia) : 4/4/2009 7:51:47 PM GMT
Would be really cool though.
BTW, Tesla, I would also like a 1.5GJ capacitor bank. Man, the destruction you could do with something like that...(0.5*3000F*1000V^2) LOL
there are 2 reasons I can think why it may still blink.
1) cap size not enough for current. or you put the cap in series instead of between power and ground after the diode.
2) near by high frequency signal interfering. this can be a real problem if you don't have good grounding. high frequency signal lines should be surrounded by ground lines.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
Just getting back to what you said originally because this is very important. It doesn't matter what calculations you do because once the motors immediately change direction you can at least expect effectively a short-circuit across your power supply. It is bad enough when a motor first starts but if it is already moving in one direction and then suddenly you reverse it then you are also "fighting" the back emf of the motor as it appears as a DC generator connected in reverse to your power. Arrange if you can a "dead" time in between changing direction and if possible PWM the motor up to speed. You will immediately find that you can get away without those enormous capacitors although they are never a bad thing to have. Once again though, use the diode + capacitor feed for the logic whenever you are hanging your motors off the same supply.
*Peter*
Donald
0.5*1F*550V^2=151kJ in series
not as much power. 1000x 495-3953-ND would give you 3,000,000 V enough power to jump over 3m
Post Edited (mctrivia) : 4/5/2009 4:02:49 AM GMT
Then you can use whatever characters you want, and you can write μF or whatever you like.· Although, being a Florida Gator, I think mention of UF enhances any discourse.
Σεε?
With Icelandic characters, you can even write Anglo-Saxon.· Don´t you ðink þæt´s nice?
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 4/5/2009 1:34:09 PM GMT
If he has them hooked-up correctly the diode feed followed by the cap should be going to the logic only whereas the motor connects directly to the input power. The motors don't really need any big caps. With a momentary heavy load on the supply the logic supply should hold up long enough until the motor starts moving.
*Peter*
Well, I suppose current could drain into the motor from the capacitors; that means merely that the power supply is inadequate to begin with.· The solution is not to place an additional 3/4 of a volt (or more) additional drop in line with the part of the circuit that is already suffering power loss.
Me, I'd power the motors and the electronics separately, or get an adequate power supply for both.
My car battery is rated at 1000A but when I start my car the lights will dim and the radio would shut off if not for the diode and .5F cap in there to keep it running.
Maxwell does sell "power cache" of those cells wired up for 144v with balancing circuits, but i dont have that kind of money, with each 3kF cell at 100$ a pop.
I once hooked a small cdrom brushed dc motor to with with a cd on it and it spun for days.
