Power problems — Parallax Forums
Power problems
pilot00pilot00 Posts: 30
edited 2009-04-14 06:13 in Propeller 1
I have a 7.5 v 1amp power supply that I purchased for Parallax. I am running a ping sensor, three servos and a two line lcd.
The lcd flickers and goes out. Tech support suggested a larger capacitor (I am on a breadboard). I changed to a 2200 mf from the
1000 mf cap at the five volt output. The lcd continues to flicker. One servo is a standard that is panning. The other two are simulating
a tracked robot's motion. When the tracked simulation changes direction the change in current cuts out the lcd entirely.
According to my calculations and going over them with the support staff, I should not have a problem with power.
Any ideas?
    edited 2009-04-04 18:16
    seperate the motors from the screen with diodes. then place large caps at least 1000uF after each diode. if you have a 1000mF great but be careful with super caps like that you need current limiting resisters.
    Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
  • pilot00pilot00 Posts: 30
    edited 2009-04-04 18:32
    I'll try the caps and diodes and see what happens. Thanks. I will post the results. I will check out the PropMod.
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-04-04 19:26
    Just for future reference, pilot00, you are probably using the wrong notation for your capacitors. mF means "milli-Farad", while uF means "micro-Farad". A 1000mF capacitor is a 1 Farad capacitor - a HUGE capacitor. Your capacitors are more likely to be 1000uF, which is 1mF, not 1000mF.
    edited 2009-04-04 19:29
    and I just assumed he was trying super caps(not really.)
    I do have this 1F cap very fun to play with
  • TeslaTesla Posts: 55
    edited 2009-04-04 19:33
    Little of subject but i have 2 3000F 2.7v boost caps from maxwell technology........those are a force to be reckoned with. they will heat up jumper cables if you discharge it with them.
    sorry to get off subject
    edited 2009-04-04 19:46
    were did you get 3000F caps? to bad voltage is so low. I can invision making a pretty powerful rail gun with caps that big in the 1000V range.
    How much?
    Post Edited (mctrivia) : 4/4/2009 7:51:47 PM GMT
    edited 2009-04-04 19:54
    3000F at 1000V would be more like a rail cannon or possibly orbital launcher. Charging them might even cause a blackout wink.gif
    edited 2009-04-04 19:59
    orbital launcher is actually what I would like to build but I already figured out it would take over a 1km long rail gun to do it in reality and a ridiculous amount of power.
    Would be really cool though.
    edited 2009-04-04 23:32
    I tried the caps and diodes. Seems to be somewhat better. LCD continues to flicker but the power does not fail.
    edited 2009-04-04 23:34
    Thanks for the milli versus micro I am aware of that, though. Is there a character set that I can access when using the forums???
    edited 2009-04-05 00:35
    The only character, and the most common, is just "u" to designate mu for micro. You could always just say "microFarad" or just "uF". Most everyone knows what you mean. [noparse]:)[/noparse]
    BTW, Tesla, I would also like a 1.5GJ capacitor bank. Man, the destruction you could do with something like that...(0.5*3000F*1000V^2) LOL
    edited 2009-04-05 01:04
    do you know the current draw?
    there are 2 reasons I can think why it may still blink.
    1) cap size not enough for current. or you put the cap in series instead of between power and ground after the diode.
    2) near by high frequency signal interfering. this can be a real problem if you don't have good grounding. high frequency signal lines should be surrounded by ground lines.
    edited 2009-04-05 01:07
    Philldapill with 1000/2.7 caps you could still build a marcs generator to get that power.
    edited 2009-04-05 01:31
    In 1970 my lecturer told us that a 1F capacitor was basically an impossibility - It would take the size of the lecture room. That's progress !!
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    · Search the Propeller forums (via Google)
    edited 2009-04-05 01:55
    in traditional caps yes. supper caps don't work the same. to bad those 3000f caps are $150 I think I could run a prop off 1 of those for 10 years before it dropped to 1.8 v the lowest my boost supply can use.
    edited 2009-04-05 03:05
    pilot00 said...
    Any ideas?
    Just getting back to what you said originally because this is very important. It doesn't matter what calculations you do because once the motors immediately change direction you can at least expect effectively a short-circuit across your power supply. It is bad enough when a motor first starts but if it is already moving in one direction and then suddenly you reverse it then you are also "fighting" the back emf of the motor as it appears as a DC generator connected in reverse to your power. Arrange if you can a "dead" time in between changing direction and if possible PWM the motor up to speed. You will immediately find that you can get away without those enormous capacitors although they are never a bad thing to have. Once again though, use the diode + capacitor feed for the logic whenever you are hanging your motors off the same supply.
    *Peter*
  • shanghai_foolshanghai_fool Posts: 149
    edited 2009-04-05 03:43
    Cluso99 said...
    I have almost 100 1.0F @5.5V that I purchased 10 yrs. ago for a project that never got off the ground. They are 3/4" dia. x 1/4" thick. So how much energy would that bag store?
    Donald
    edited 2009-04-05 03:46
    0.5*100F*5.5V^2=1.5kJ in paralel.
    0.5*1F*550V^2=151kJ in series
    edited 2009-04-05 03:54
    now imagine a marx generator with 3000F 1000V caps. That would be one powerful bolt.
    not as much power. 1000x 495-3953-ND would give you 3,000,000 V enough power to jump over 3m
    Post Edited (mctrivia) : 4/5/2009 4:02:49 AM GMT
    edited 2009-04-05 03:56
    mctrivia, the arrangement dependance struck me as odd with the energy being different if they are in series or parallel. Then a light bulb went off. You are forgeting that the capacitance will be 1/100th of 1F when they are in parallel. The energy would be about 1.5kJ if they are in parallel OR series. Don't worry - it happens to the best of us. [noparse]:)[/noparse]
    edited 2009-04-05 04:02
    in parallel caps add up. I think you ment series. your right i forgot about the fact they divide in series.
    edited 2009-04-05 04:11
    Ha! You're right. See, it happens to the best of us!
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-04-05 13:27
    Philldapill said...
    If you are using Windows XP, you can add the Greek language support, very easy to do in Control Panel under Regional and Language Options.·
    Then you can use whatever characters you want, and you can write μF or whatever you like.· Although, being a Florida Gator, I think mention of UF enhances any discourse.
    Σεε?
    With Icelandic characters, you can even write Anglo-Saxon.· Don´t you ðink þæt´s nice?
    · -- Carl, nn5i@arrl.net
    Post Edited (Carl Hayes) : 4/5/2009 1:34:09 PM GMT
    edited 2009-04-05 15:13
    pilot00 said...
    Get rid of the diodes.· All they're doing is reducing your available supply voltage.
    edited 2009-04-05 15:33
    Carl,
    If he has them hooked-up correctly the diode feed followed by the cap should be going to the logic only whereas the motor connects directly to the input power. The motors don't really need any big caps. With a momentary heavy load on the supply the logic supply should hold up long enough until the motor starts moving.
    *Peter*
    edited 2009-04-05 18:02
    Carl, if I understand it correctly, and if this is the way he has them laid out, the diodes are preventing the caps from draining out with the sudden rush of current when the motor turns on. I had a similiar problem with a high-power(50A) mosfet switching circuit. The supply for the logic was the same as the supply for the motor(yes, bad practice). What would happen, is when the mosfets would turn on for the motor, there would be a massive voltage drop, causing my logic supply to bleed out to the motor. Often, this would cause a reset or other problems. Adding a diode in between the positive supply, and my logic supply caps fixed the problem. Current could fill up the capacitors, but would block the caps from discharging when the motor turned on.
    edited 2009-04-05 19:39
    Philldapill said...
    But there are already diodes in the power supply.· Current cannot backdrain into the power supply, so those additional diodes do nothing.
    Well, I suppose current could drain into the motor from the capacitors; that means merely that the power supply is inadequate to begin with.· The solution is not to place an additional 3/4 of a volt (or more) additional drop in line with the part of the circuit that is already suffering power loss.
    Me, I'd power the motors and the electronics separately, or get an adequate power supply for both.
    edited 2009-04-05 19:46
    If you take a motor and reverse its direction it will act as a dead short for a split second. This will drain all power from the system no mater how powerful your power supply is.
    My car battery is rated at 1000A but when I start my car the lights will dim and the radio would shut off if not for the diode and .5F cap in there to keep it running.
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2009-04-05 21:23
    on Windows systems, µ = alt 0181. If you're using a laptop without a keypad, you have to shift into the numlock mode. (Read your manual)
    edited 2009-04-05 23:44
    I did buy them for 150$ a pop from someone that retails the BoostCap series of maxwell tech. They are rated 600amp discharge and charge. They are rated to completely short out with no damage. The low voltage is due to how they are constructed.
    Maxwell does sell "power cache" of those cells wired up for 144v with balancing circuits, but i dont have that kind of money, with each 3kF cell at 100$ a pop.
    I once hooked a small cdrom brushed dc motor to with with a cd on it and it spun for days.
