Connecting pins on non-printed curcuit board
I an trying to prototype a board. I tried to solder the points together but made a total mess. I want to connect an adc0838 to the prop on a prop protoboard. Insert dip, solder pins no problem. How do I connect the pins to the prop?
I have tried bending the pins of the dip and soldering wire to the pins. Looks terrible.
How do you connect two holes together neatly.
·Any help is appreciated.
Don
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Don
Radioshack carries it... The have a whole bunch of boards that have the same think... just holes. I asked the guy... ok... so how do you use these?... and i think he said "circuit wire." Some of the guys say "wire wrap them"... which from the paleolithic period and there is no longer anyone who can describe the technique...
If you Google "wire wrap"... is simply says to go to RadioShack.
I personally take everything off board and connect them with 3 wire ribbons.
Mike2545
This message sent to you on 100% recycled electrons.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Mike2545
I just got the idea. Strip the wire and tint. Twist with a pair of twisors. Place on pin and solder them together.
I will be going to Radio Shack this afternoon. I will ask about circuit wire. Thanx for the idea.
