Opening Oem Gerber files — Parallax Forums
electromanjelectromanj Posts: 270
edited 2009-03-30 21:37 in BASIC Stamp
Hello, I have downloaded the oem gerber files. I also have downloaded viewmate. I am able to open bs2a2, but am unable to open bs2b. The bs2a2 is the 2 sided board, and I believe the bs2b is the one sided version which is what I need. Anybody have any suggestions? I don't really need the gerber file just a picture of the trace routing as I am using express pcb for my board design and I dont think I can import a gerber file.
Thanks!
  • ForrestForrest Posts: 1,341
    edited 2009-03-30 00:17
    When you run Viewmate, you should choose Import Gerber - not Open File. I can confirm the OemBS2b.G?? files are 274X gerber files - so they should import into Viewmate. The other files in the folder is an aperture file (not needed) and drill files or drill reports.
  • electromanjelectromanj Posts: 270
    edited 2009-03-30 00:31
    Thanks for the quick reply, I tried to import gerber bs2b2 gerber and recieved many errors. Viewmate says one file imported with errors. Unable to see the board. any other ideas?
    edited 2009-03-30 00:33
    Anybody have a copy of the trace routing in pdf?
    edited 2009-03-30 05:15
    You could try viewing it with GC Preview instead.
    edited 2009-03-30 15:22
    electromanj,
    Here is a link to several "free" gerber viewers. I have used CAMTASIC in the past. "GC Preview" is also on the list.
    www.mitsi.com/pcb/free%20viewers.htm
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/31/2009 4:23:38 AM GMT
    edited 2009-03-30 15:47
    Thanks, I'll try that.
    Thanks to all for the help. I was able to view it with GC preview. Now if I only learn to operate gc preview......
    Thanks again!!
