Another RGB LED experiment - not long, with pictures. — Parallax Forums
PLJackPLJack Posts: 398
edited 2009-04-16 12:45 in General Discussion
Color. There are many models for producing color.
For our purpose the RGB color model is the most important.
I've had some frustration producing color with RGB LED's. So I decided to do a weekend study and share it with you.
One would think that if we have a Red, Green and Blue LED that we could produce any color that we wanted. This is not the case.
LED's do not precisely follow the RGB color model. A lack of the color black is one of the culprits. (no, turning the room lights off won't work). In most color models black is used to produce saturation. Take the color Gray for instance. A computer monitor with RGB pixels can produce a gray color because black is the base color. A RGB LED will only be able to produce white. As you try to make darker gray's you just end up with a dimmer white. And it doesn't stop there. Many laws of color fall apart with RGB LED's.
So, just what colors can we produce with RGB LED's.
First we need a test unit. In this case I am using the Parallax SX 48 Proto board.
A Nichia NSSM016C RGB LED. (thanks StarMan). And three adjustable 1K resistors. I have found that it is convenient, although not practical, to use adjustable resistors in order to tune the LED for a perfect white color. Using standard resistors values is perfectly OK as well, but I find the final color will have a red or blue push to it. I am using PWM to reduce the amount of voltage each LED receives. Each LED can be set to a value between 0 to 255. At zero the LED is off. As the number climbs the LED gets brighter. 255 being full brightness. The SX/B code is attached to this thread.
Here is the test unit:
Notice the plastic dome covering the LED. With this on top of the LED we can get a nice defuse color. I spent more hours trying to get a "too smart for its britches" digital camera to take decent pictures than I did coding for the project. Just when I was ready to give up I remembered that I had a little dome AC night light. The plastic dome is perfect for this application. That and the discovery that I can tell my camera what to look at to decide its exposure time saved this project. The colors are somewhat inaccurate but you can still gauge the color reproduction of the LED.
First, let's try the MS Windows system colors, just to see what happens. This palette consists of the following colors:
clBlack, clMaroon, clGreen, clOlive, clNavy, clPurple, clTeal, clGray, clSilver, clRed, clLime, clYellow, clBlue, clFushsia, clAqua, clLtGray, clDkGray and clWhite.
And performed it with this code:
'__________________________________________________________
' S_CycleSystemColor            SUB     0
' Simply cycles the pseudo system colors.
S_CycleSystemColors:
FOR UtilVar = 0 TO clSysColorMax
        READ D_SystemRed        + UtilVar, RedVal
        READ D_SystemGreen      + UtilVar, GreenVal
        READ D_SystemBlue       + UtilVar, BlueVal
        PAUSE LongDelay
NEXT
RETURN
Here are the results.
The colors that failed are Maroon, Olive, Navy, Teal, Gray, Silver, LtGray and DkGray.
Navy shows a blue. Teal as Aqua(Cyan) and of course all the grays are just dim whites.
Not too much of a surprise really.
Next lets try the Additive Color palette. This is the basic RGB color model.
Let's start with red and move counterclockwise to white using this code:
' S_CyclePrimaries              SUB     0
' Cycles the primary additive colors.
' http://en.wikipedia.org/wiki/RGB
S_CyclePrimaries:
S_RGB 255, 0, 0         'RED
PAUSE LongDelay
S_RGB 255, 255, 0       'Yellow
PAUSE LongDelay
S_RGB 0, 255, 0         'Green
PAUSE LongDelay
S_RGB 0, 255, 255       'Cyan
PAUSE LongDelay
S_RGB 0, 0, 255         'Blue
PAUSE LongDelay
S_RGB 255, 0, 255       'Purple
PAUSE LongDelay
S_RGB 255, 255, 255     'White
PAUSE LongDelay
RETURN
Here are the results:
The camera under exposed yellow and white but the results are excellent. RGB LED's have no problem producing these seven colors. This is also not a surprise. All the RGB values are either 0 or 255. Simply a pure mix of the additive colors.
Now lets push RGB LED's way outside of their realm by trying to reproduce the Subtractive Color palette model. Our model will be the standard subtractive wheel.
The code:
' S_CycleSubtractivePrimaries       SUB     0
' Cycles the subtractive primary colors.
' http://en.wikipedia.org/wiki/Subtractive_color
S_CycleSubtractivePrimaries:
FOR UtilVar = 0 TO SubtractiveMax
        READ D_SubtractivePrimaryRed    + UtilVar, RedVal
        READ D_SubtractivePrimaryGreen  + UtilVar, GreenVal
        READ D_SubtractivePrimaryBlue   + UtilVar, BlueVal
        PAUSE LongDelay
NEXT
RETURN
The results:
Every color that is not close to the seven additive colors fail miserably.
Some are worse than others. The big surprise is the color on top of the wheel that appears to be yellow. The issue is that the RGB values of that color are (254-254-51). In additive color land that is not yellow (255-255-0). The end result is a "dead fish belly yellow".
So, there you have it. Download the code and have fun.
I would be interested in any results or theories you come up with. Mine are based on the observations of this experiment and not an exhaustive study.
NOTE: Small bug fix to code. Attached in next response.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Post Edited (PLJack) : 10/1/2007 10:18:03 PM GMT
    edited 2007-09-30 18:22
    One of the major application areas for the TAOS TCS230 color sensor is feedback for lighting systems such as yours. You could stick one of these sensors under the dome with the LED and measure the reflected color to adjust your PWMs. Once you've performed a white balance on the TCS230, you wouldn't even need the trimpots.
  • PLJackPLJack Posts: 398
    edited 2007-09-30 18:35
    Updated code attached:
    '   File...... RGBColors.sxb
    '   Purpose... Demonstrate RGB Color Models
    '   Author.... Jack Kelly (PLJack)
    '   E-mail....
    '   Started... Sept 21, 2007
    '   Updated... Sept 23, 2007
    ' Device Settings
    DEVICE SX48, OSC4MHZ
    'DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
    FREQ 4_000_000
    ' IO Pins
    PWM_R    PIN RD.0 OUTPUT  ' Red LED Pin
    PWM_G    PIN RD.1 OUTPUT  ' Green LED Pin
    PWM_B    PIN RD.2 OUTPUT  ' Blue LED Pin
    ' Constants
    '--- Common Anode
    LEDOn           con     0
    LEDOff          con     1
    '--- Common Cathode
    'LEDOn          con     1
    'LEDOff         con     0
    '--- MS Windows system colors.
    clSysColorMax   CON 17
    SubtractiveMax  CON 12
    clBlack         CON 0
    clMaroon        CON 1
    clGreen         CON 2
    clOlive         CON 3
    clNavy          CON 4
    clPurple        CON 5
    clTeal          CON 6
    clGray          CON 7
    clSilver        CON 8
    clRed           CON 9
    clLime          CON 10
    clYellow        CON 11
    clBlue          CON 12
    clFuchsia       CON 13
    clAqua          CON 14
    clLtGray        CON 15
    clDkGray        CON 16
    clWhite         CON 17
    '--- Used for loop delays and pausing in general
    FastDelay       CON 15
    ShortDelay      CON 500
    LongDelay       CON 1000
    ' Variables
    PwmCounter      var     Byte    '--- Controls voltage to
                                    '--- LEDs via the
                                    '--- INTERRUPT routine.
    RedVal          var     Byte    '--- RGB values
    GreenVal        var     Byte    '--- 0 is off.
    BlueVal         var     Byte    '--- 255 IS FULL ON
    UtilVar         var     Byte    '--- Used for loops.
    INTERRUPT 25000         '--- Adjusted up until LED stopped
                            '--- blinking. Feel free to change
                            '--- it to your liking.
     ISR_Start:
            Inc PwmCounter  '--- Add one to pwm counter.
                            '--- Note: it rolls over to 0 at 255.
            if PwmCounter = 0 then  '--- If a led value, RedVal
                    Inc PwmCounter  '--- for  example, is zero
            endif                   '--- we want the led to
                                    '--- receive no voltage.
                                    '--- So, if PwmCounter is
                                    '--- zero we add one to it
                                    '--- so that it will  pass
                                    '--- the IF statement below
            '--- Red LED PWM
            if PwmCounter > RedVal then
                    PWM_R = LEDOff
            else
                    PWM_R = LEDOn
            endif
            '--- Green LED PWM
            if PwmCounter > GreenVal then
                    PWM_G = LEDOff
            else
                    PWM_G = LEDOn
            endif
            '--- Blue LED PWM
            if PwmCounter > BlueVal then
                    PWM_B  = LEDOff
            else
                    PWM_B = LEDOn
            endif
    ISR_Exit:
    RETURNINT
    ' Declare Subroutines
    S_Calibration                   SUB     0
    S_RGB                           SUB     3
    S_SystemColor                   SUB     1
    S_CycleSystemColors             SUB     0
    S_MixPrimaries                  SUB     0
    RampRed                         SUB     0
    SlideRed                        SUB     0
    RampGreen                       SUB     0
    SlideGreen                      SUB     0
    RampBlue                        SUB     0
    SlideBlue                       SUB     0
    Blink                           SUB     0
    ' Program Code
    PROGRAM Start
    Watch RedVal
    watch GreenVal
    watch BlueVal
    Start:
    S_RGB 0, 0, 0                   '--- Turn all LEDs off.
    ' Main
    Main:
    'S_Calibration                  '--- Used to calibrate LEDs
    'GOTO Main                      '--- See S_Calibration func
    'S_CycleSystemColors            '--- Uncomment to enable
    'Blink                          '--- ...
    'S_CyclePrimaries               '--- Uncomment to enable
    'Blink                          '--- ...
    'S_CycleSubtractivePrimaries    '--- Uncomment to enable
    'Blink                          '--- ...
    S_MixPrimaries
    GOTO Main
    ' Subroutine Code
    ' S_Calibration:
    ' I used adjustable POTs on my RGB LED. I let this function
    ' run as I turn the POT on each LED.
    ' Once I have a nice white color I disable this function.
    S_Calibration:
    FOR UtilVar = 0 TO 255
            S_RGB UtilVar, UtilVar, UtilVar
            PAUSE 20
    NEXT
    S_RGB 128, 128, 128
    PAUSE 5000
    RETURN
    ' S_RGB                           SUB     3
    ' Simply transfers the three parameters to the RGB Values.
    S_RGB:
    RedVal =        __PARAM1
    GreenVal =      __PARAM2
    BlueVal =       __PARAM3
    RETURN
    ' S_SystemColor                   SUB     1
    ' Recreates the standard MS Windows system colors.
    ' Pass this function one of the clColor constants
    ' listed above.
    S_SystemColor:
            READ D_SystemRed        + __PARAM1, RedVal
            READ D_SystemGreen      + __PARAM1, GreenVal
            READ D_SystemBlue       + __PARAM1, BlueVal
    RETURN
            PAUSE LongDelay
    NEXT
    RETURN
    S_CyclePrimaries:
    PAUSE LongDelay
    PAUSE LongDelay
    PAUSE LongDelay
    PAUSE LongDelay
    PAUSE LongDelay
    PAUSE LongDelay
    PAUSE LongDelay
    RETURN
            PAUSE LongDelay
    NEXT
    RETURN
    ' S_CycleRGB                    SUB     0
    ' This will transverse through all possible
    ' color combinations.
    S_MixPrimaries:
    RampRed
    PAUSE ShortDelay
    RampGreen
    PAUSE ShortDelay
    SlideRed
    PAUSE ShortDelay
    RampBlue
    PAUSE ShortDelay
    SlideGreen
    PAUSE ShortDelay
    RampRed
    PAUSE ShortDelay
    SlideBlue
    PAUSE ShortDelay
    SlideRed
    PAUSE ShortDelay
    RETURN
    ' RampRed                        SUB     0
    ' From dim to bright.
    RampRed:
            IF RedVal < 255 then
                    INC RedVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' SlideRed                       SUB     0
    ' Bright to dim.
    SlideRed:
            IF RedVal > 0 then
                    DEC RedVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' RampGreen                      SUB     0
    RampGreen:
            IF GreenVal < 255 then
                    INC GreenVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' SlideGreen                     SUB     0
    ' Bright to dim.
    SlideGreen:
            IF GreenVal > 0 then
                    DEC GreenVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' RampBlue                       SUB     0
    RampBlue:
            IF BlueVal < 255 then
                    INC BlueVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' SlideBlue                      SUB     0
    ' Bright to dim.
    SlideBlue:
            IF BlueVal > 0 then
                    DEC BlueVal
            ENDIF
    PAUSE FastDelay
    NEXT
    RETURN
    ' Blink                         SUB     0
    ' Just a blink that we can reconize.
    Blink:
    S_RGB 0,0,0
    PAUSE ShortDelay
    S_RGB 255,0,0
    PAUSE ShortDelay
    S_RGB 0,0,0
    PAUSE ShortDelay
    S_RGB 0,0,255
    PAUSE ShortDelay
    S_RGB 0,0,0
    RETURN
    ' DATA statement for color models.
    D_SystemRED:
    DATA    0
    DATA    128
    DATA    0
    DATA    128
    DATA    0
    DATA    128
    DATA    0
    DATA    128
    DATA    192
    DATA    255
    DATA    0
    DATA    255
    DATA    0
    DATA    255
    DATA    0
    DATA    192
    DATA    128
    DATA    255
    D_SystemGreen:
    DATA     0
    DATA     0
    DATA     128
    DATA     128
    DATA     0
    DATA     0
    DATA     128
    DATA     128
    DATA     192
    DATA     0
    DATA     255
    DATA     255
    DATA     0
    DATA     0
    DATA     255
    DATA     192
    DATA     128
    DATA     255
    D_SystemBlue:
    DATA     0
    DATA     0
    DATA     0
    DATA     0
    DATA     128
    DATA     128
    DATA     128
    DATA     128
    DATA     192
    DATA     0
    DATA     0
    DATA     0
    DATA     255
    DATA     255
    DATA     255
    DATA     192
    DATA     128
    DATA     255
    D_SubtractivePrimaryRed:
    DATA    254
    DATA    250
    DATA    251
    DATA    253
    DATA    254
    DATA    167
    DATA    134
    DATA    61
    DATA    2
    DATA    3
    DATA    102
    DATA    208
    D_SubtractivePrimaryGreen:
    DATA    254
    DATA    188
    DATA    153
    DATA    83
    DATA    39
    DATA    25
    DATA    1
    DATA    1
    DATA    71
    DATA    146
    DATA    176
    DATA    234
    D_SubtractivePrimaryBlue:
    DATA    51
    DATA    2
    DATA    2
    DATA    8
    DATA    18
    DATA    75
    DATA    175
    DATA    164
    DATA    254
    DATA    206
    DATA    50
    DATA    43
    - - - PLJack - - -
    edited 2007-09-30 18:46
    Phil Pilgrim (PhiPi) said...
    $5.60 a pop though. I can think of allot of applications for that.
    Thanks.
    BTW: The camera did a mediocre job at reproduction. The colors look beautiful on the bench.
    - - - PLJack - - -
  • T&amp;E EngineerT&amp;E Engineer Posts: 1,396
    edited 2007-09-30 19:22
    Great job PLJack!
    I would like to try this on my 8x8 RGB Led matrix (one RGB Led set first) and then maybe expand it out.
    It looks like you used potentiometers for current limiting resistors in your SX-48 pics. Do you have any connection schematics? Or at least tell me what value resistors to use? I'm thinking 220 - 470 ohms until I get into moving displays and then it would be less resistance for better brightness due to the lower duty cycle of LED on time.
    Very neat!
    edited 2007-09-30 19:46
    T&E Engineer said...
    Great job PLJack!
    Any LED driver calculator will work to get your values.
    such as this one. LED calculator
    As for my pots, they are 0 to 1K pots. I don't know the exact values that are currently set to.
    Roughly 30 to 35%. I could have gone lower but its not good to stare at a bright LED for two days. smile.gif
    - - - PLJack - - -
    edited 2007-10-08 04:55
    112 views and only one question.
    That's a good thing.
    - - - PLJack - - -
    edited 2007-10-08 16:54
    We use Led light fixtures at work controlled by DMX, the same problem applies even when using tv broadcast quality cameras only a handful of colors seem to give pleasant results the others are either washed out or just look white, filters in front help a bit but you certainly will not be able to distinguish the 16 million colours as quoted in the blurb.
  • JomsJoms Posts: 279
    edited 2009-03-28 01:17
    Sorry if I didn't find this in your post... Would you mind sharing where you found your LED? It looks like something I would love to use on a few projects...
    Thanks...
    edited 2009-03-28 21:11
    Joms said...
    Thanks...
    I looked through my old orders, did not see it.
    I'm pretty sure I bought it via Ebay from a use of these forums called StarMan.
    I can highly recommend these ones though:
    www.mouser.com/Search/ProductDetail.aspx?R=AAF5060PBESEEVGvirtualkey60400000virtualkey604-AAF5060-RGB
    www.mouser.com/Search/ProductDetail.aspx?R=OVSARGB3R8virtualkey54210000virtualkey828-OVSARGB3R8
    - - - PLJack - - -
    edited 2009-03-29 12:51
    PLJack - Nice write up and pictures. Really nice pictures!
    Do you think using an LED driver (instead of the SX outputs) would change anything? I have a RGB LED surface mounted to a new product for Brilldea that includes an Allegro Microsystems A6281 constant current LED driver. This IC has three channels and each channel has 10-bit control as well as dot correction control. Check out the IC here: http://www.allegromicro.com/en/Products/Part_Numbers/6281/index.asp
    If you are interested in this device I can post pictures tomorrow and send you one or two by post for testing. I have some very rudimentary code written for the Propeller to control this product, but nothing for the SX. In the coming week I will be writing a complete driver for the Propeller.
    You said you used PWM for your control at 8-bits resolution. Is there any advantage (beside reducing processing overhead) to using a BAM method (bit amplitude angle modulation)? You might be able to increase the resolution also with this method.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    Post Edited (Timothy D. Swieter) : 3/29/2009 2:05:38 PM GMT
    edited 2009-03-29 13:25
    Timothy,
    What is BAM? Google has nothing on it as it is a first for my ears.
    Thanks.
    Tom Smykowski: Well-well look. I already told you: I deal with the customers so the engineers don't have to. I have people skills; I am good at dealing with people. Can't you understand that? What is wrong with you people?
    edited 2009-03-29 14:01
    BAM = Bit Angle Modulation. I see I got that wrong in my previous post, I will correct that.
    BAM is a method of intensity control for LEDs published by Artistic Licence. The basics is that you define a bit period and a your resolution. Let's say the bit period is x and the resolution is 8 bits. If the first bit is on, then the output is one for x time. If the second bit is on, then the output is on for 2x and so on. This is probably over simplified. There are couple app notes/resources on Artistic Licence web site. The BAM method and publishing was done to combat certain companies in the LED lighting industry who were patenting everything - including PWM control of RGB LEDs! (lets not go there and take this thread off topic)
    Web site: www.artisticlicence.com/
    App Note: www.artisticlicence.com/WebSiteMaster/App%20Notes/appnote011.pdf
    I plan on writing a Propeller driver for another product I have nearly finished in hardware design that will use the BAM method of intensity control. I believe there are also a few posts on the web with PIC and AVR projects using BAM.
    www.tdswieter.com
  • danny270danny270 Posts: 13
    edited 2009-04-13 15:46
    PL Jack,
    Can you help me understand how the data statements for the color models were arrived at? This may be a stupid question but I would appreciate if I find out the logic behind it.
    Thanks.
    Danny
  • BeanBean Posts: 8,129
    edited 2009-04-14 17:21
    ·Danny,
    · Here is a BAM implementation for the SX.
    ·Bean
    ' Bit Angle Modulation
    DEVICE SX28,OSC4MHZ
    FREQ 4_000_000
    LED      PIN RB.7 OUTPUT
    pwmValue VAR BYTE
    ' Interrupt variables
    bamBit   VAR BYTE
    intTemp  VAR BYTE
    INTERRUPT NOPRESERVE
      bamBit = bamBit >> 1
      IF bamBit = 0 THEN
        bamBit = 128
      ENDIF
      intTemp = pwmValue AND bamBit
      IF intTemp <> 0 THEN
        LED = 1
      ELSE
        LED = 0
      ENDIF
    RETURNINT bamBit
    PROGRAM Start NOSTARTUP
    Start:
      bamBit = 1
      OPTION = %1000_0101 ' Prescale 64:1 = 244Hz update rate (Prescaler must be > cycles used in the interrupt)
      DO
        FOR pwmValue = 0 TO 255 STEP 15
          PAUSE 50
        NEXT
        FOR pwmValue = 255 TO 0 STEP -15
          PAUSE 50
        NEXT
      LOOP
    END
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    edited 2009-04-15 13:46
    danny270 said...
    PL Jack,
    Thanks.
    Danny
    Hi Danny.
    The DATA statements hold the RGB color values for each color model examined.
    For example, The first four colors in the Windows system color model are clBlack, clMaroon, clGreen, clOlive.
    Like so.
    D_SystemRED:
    DATA 0
    DATA 128
    DATA 0
    DATA 128
    D_SystemGreen:
    DATA 0
    DATA 0
    DATA 128
    DATA 128
    D_SystemBlue:
    DATA 0
    DATA 0
    DATA 0
    DATA 0
    The first value from each of the list above is 0, 0, 0. Black, ie: all leds off.
    The second value from each is 128, 0, 0. Which is Maroon (Red at half brightness).
    Third from each is 0, 128, 0, Green (at half brightness) Full green, 254, is actually defined as Lime
    The numbers come from the RGB values defined in the Windows system pallet.
    Then we just cycle through the colors:
    PAUSE LongDelay
    NEXT
    clSysColorMax is defined as 17 because there are 18 colors listed in each of the D_SystemX data statements.
    Hope that helps.
    Jack
    - - - PLJack - - -
    edited 2009-04-15 14:08
    Timothy D. Swieter said...
    PLJack -
    I know, late reply from me. That's not news[noparse]:)[/noparse]
    Just read up on BAM. Pretty cool stuff.
    As for increasing resolution it's been my experience that 8 bits is too much as it is.
    Your eye will not notice 256 levels of brightness on an LED.
    For RGB LEDs I'm would say that 4 bit is plenty (16 levels of brightness). 6 bit (64 levels) is definitely more that the beholder will be able to make out.
    Just thought I would mention that.
    Jack
    - - - PLJack - - -
    edited 2009-04-15 14:20
    Bean (Hitt Consulting) said...
    Danny,
    [noparse][[/noparse]/code]
    Yes, thanks for that Bean.
    I'm currently trying to write code to run a 5x7 LED matrix that will have 8 shades of gray (brightness).
    In other words I need to PWM each led, as opposed to cycling each column.
    Not sure how but I see something useful in that example.
    BTW, the STEP command had me confused. Never used it before.
    How did I miss such a useful command?
    Jack
    - - - PLJack - - -
    edited 2009-04-15 21:37
    Jack,
    The datasheet for the RGB LED you're using contains a graph of the colorspace of the three LEDs.· The graph is shown below.· The curve drawn in the graph represents the spectral colors we can see from red (longest wavelength) to blue (shortest wavelength).· The human eye can perceive all of the colors contained within the spectral curve.· The three LEDs are located near the red, green and blue spectral colors.· I added the red triangle, which shows the colorspace that the three LEDs can produce.· Only the colors within the interior of the triangle can be produced by a combination of the three LEDs.· There is a large area between green and blue that cannot be represented by the LEDs.
    The LEDs should be able to produce a wide range of grays.· The color gray sits within the area of the triangle.· As you mentioned, it is not possible to produce black with the lights on.· The surface of the device looks white (or close to white) when ambient light shines on it.· You would have to shield the device from ambient light to be able to produce black.· The reflected light will combine with the generated light, and reduce the color saturation of the generated light.
    Dave
    654 x 760 - 23K
  • ZootZoot Posts: 2,227
    edited 2009-04-15 23:39
    If find the BAM concept totally intriguing.
    Bean -- I have a question about your SX implementation.
    I *think*, in my reading of the BAM appNote, that each bit position, if "on", results in a portion of the pulse being high, with the length *of that portion* depending on the bit position. In my reading of your code, each high bit results in an equal "portion" of the pulse being on???
    appnote011 said...
    a microprocessor generating an eight bit
    resolution BFM signal at 100Hz will need to process the output only 8
    times at 5000us, 2500us, 1250uS, 625uS, 312uS, 156uS, 78uS, 39uS
    So a 1 in bit.0 adds 39us (1x unit) to the pulse, a 1 in bit.1 adds 78us (2x unit). It seems in your code this wouldn't be the case? I.E. I should get 128x unit added to the pulse for a bit7 = 1.
    Or am I missing something simple here???
    Wouldn't there need to be something to scale the interrupt period before choosing to shift the bamBit mask? e.g.
    DEC bamAccum
    IF bamAccum = 0 THEN
       bamAccum = bamBit ' mult. of 2 cycles
       IF bamBit = 0 THEN
          bamBit = 128
       ENDIF
          LED = 1
       ELSE
          LED = 0
       ENDIF
    ENDIF
    RETURNINT
    Which would also seem to fit in better with the notion that the actual parsing of the PWM value and move to output happens much more infrequently then in "normal" PWM.
    Post Edited (Zoot) : 4/16/2009 12:48:27 PM GMT
    edited 2009-04-16 11:34
    Zoot,
    · Notice at the end of the interrupt is "RETURNINT bamBit". bamBit will be 128 for the MSB, then 64, then 32, etc. So the MSB will last 128 times longer than the LSB. This is why the precaler must be set higher than the cycles used in the interrupt, because the LSB is effectively "RETURNINT 1".
    · The whole idea of BAM is to NOT generate all those interrupts. In my implementation the interrupt code is only executed 8 times for each complete cycle.
    · If you have periodic interrupts, you might as well just use PWM.
    · Again,·appologies for not putting comments in the code. I'll update it ASAP.
    Bean.
    Post Edited (Bean (Hitt Consulting)) : 4/16/2009 11:40:14 AM GMT
    Duh, of course. Too slick.
