Incompatible firmware revision ($F).
doggiedoc
Hello friends.
Decided to get my new Javelin Stamp Demo Board up and going today. Unfortunately I can't figure out how to get it communicating with the Javelin stamp that came with it.
The error as noted in the title is Incompatible firmware revision ($F).
I have tried the current official release 2.0.3 and the previous release 2.0.1 to no avail.
Do I have a hardware issue or is there a more current release than 2.0.3 of the IDE?
My setup is:
Microsoft Windows XP - latest updates and service packs -
USB adapter: keyspan USA-19hs
Machine: 8-core Intel Xeon 3.2 GHz, 18GB Ram (Mac Pro Boot Camp on dedicated drive)
Any advice would be greatly appreciated!
Doc
My setup is:
Doc
set this to minimum.
And you can always try the IDE beta (see sticky thread).
regards peter
I don't see latency settings and I've changed other settings such as speed and FIFO buffer but to no avail.
Doc
I'm starting to wish I hadn't spent the $250 on the Javelin Stamp starter kit now. [noparse]:([/noparse]
Are you sure there is no latency setting? Have you checked
the keyspan website for FAQ etc. ?
Do you have a normal serial port on your PC that you can use?
Do you have a Parallax usb adapter (with FTDI chipset),
these are guarenteed to work with parallax products.
Do you run some kind of HotSync software that may interfere
with your ports?
You mention you have some BOE usb boards.
Have you read this thread:
http://forums.parallax.com/showthread.php?p=656527
What it comes down to is to place a 1k resistor between pin2
and pin4 of the DIP24 socket.
Contact Parallax support if all of the above does not lead to resolving
the problem.
regards peter
Post Edited (Peter Verkaik) : 3/27/2009 2:37:24 AM GMT
Oddly enough, it didn't work. But I noticed that JIDE only looks at com4 for some reason, so I deleted the other com ports, reinstalled the FTDI drivers and what do you know? It works!
I'm cooking with grease now!!!
Thanks again for the help.
Doc
