Need help deciphering serial interface specs for the following sensor...
Howdy,
I'm trying to interface an AustriaMicroSystems AS5040 sensor with a parallax SX, and think I understand everything except one parameter in the datasheet. Hopefully someone here can make a bit more sense out of it. On the bottom of page 6 in the spec sheet is the Timing Characteristics table, with a field labeled "Data Output Valid", which corresponds with figure 5 on page 9. The table indicates that the minimum data valid time is 357ns, and the max 394. Does this mean that while CLK is high, the maximum time it could take for the data to be valid is 394ns, or does it mean that the data is valid only between 357 & 394ns? Any insight is appreciated.
Mark S
Mark S
· -- Carl, nn5i@arrl.net
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
P.S.
Nice bike, Leon! I got myself an SV650
