Serial output with video generator
Hi,
Is it possible to use the video generator to transmit serial
data to multiple serial IC's
There are 8 of them and each IC has Clock, Data and Load.
I have seen many examples of the video generator but
have not been able to get my head around it.
Sincerely,
Scott
Sincerely,
Scott
Is there a way I can slow the video generator down to a crawl so I can
watch the waveforms with a scope (or a few LED's) ?
Also, what example should I start modifying: 8xPWM, Composite or VGA ?
Thanks Phil.
Scott
If the clock is done with CTRA then my bits don't need expanding (0110 ->> 00111100). Then
I'm really just pointing the video generator at my bits and off it goes ?
Scott
Yup.
Scott
For example, if your data consist of a single serial data line and a clock, and one /ENA line, your four possible values during data transmission would be:
A prologue and postlogue, when /ENA is being asserted or deasserted might have a set of "colors" like this:
Explaining the video peripheral in much further detail is beyond the scope of a forum response, I'm afraid. You really need to consult some good documentation. Andr
Thanks a bunch Phil !
Scott
