What Do You Call This Connector and Where Can I Buy Them?
Bill Chennault
All--
Super dumb question.
What do you call this connector and where can I buy them?
IDEALLY, I would like to have a long strip of these things instead of two positions at a time. In my MIND, they should come in 4, 8, 16, and 32 connector strips and handle 18 - 24 gauge hookup wire.
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
See this page of their catalog:
www.jameco.com/Jameco/catalogs/c291/P71.pdf
They are called Terminal Blocks.
Kenny
Ones that I have purchased before (and some of the ones in the Jameco Page) are available in two position or three position. They then have guides and slots so that the Terminal Block can be attached together to make any arrangement and size that you need. The picture of the Terminal blocks you posted don't look to have the guides/slots.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Robert
Signature space for rent!
Send $1 to CannibalRobotics.com.
Chris Savage
Parallax Engineering
