What Do You Call This Connector and Where Can I Buy Them? — Parallax Forums
Bill ChennaultBill Chennault Posts: 1,198
edited 2009-03-20 15:07 in General Discussion
All--
Super dumb question.
What do you call this connector and where can I buy them?
IDEALLY, I would like to have a long strip of these things instead of two positions at a time. In my MIND, they should come in 4, 8, 16, and 32 connector strips and handle 18 - 24 gauge hookup wire.
Thanks!
--Bill
You are what you write.
  • Kenny GardnerKenny Gardner Posts: 169
    edited 2009-03-19 18:50
    Jameco has them.
    See this page of their catalog:
    www.jameco.com/Jameco/catalogs/c291/P71.pdf
    They are called Terminal Blocks.
    Kenny
    edited 2009-03-19 23:22
    Also called screw terminal blocks.
    Ones that I have purchased before (and some of the ones in the Jameco Page) are available in two position or three position. They then have guides and slots so that the Terminal Block can be attached together to make any arrangement and size that you need. The picture of the Terminal blocks you posted don't look to have the guides/slots.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    edited 2009-03-19 23:30
    If you need some of those terminal blocks in a hurry you can check the parts bins at Radio Shack.· As I recall a lot of the stores actually stock those in blue.· It would be worth checking into.
    Robert
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2009-03-20 01:43
    The radio shack versions come in pairs that can be snapped together into long barrier strips too.
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
    Actually those do have the plastic tabs and grooves for joining them. It's a single piece you can see in the picture on the single TB, back right. To connect them together you have to actually place one above the other and guide it down over the plastic tab.
    Parallax Engineering
