Buzzer 555 Timer Circuit from SX — Parallax Forums
Chicago MikeChicago Mike Posts: 88
edited 2009-03-20 03:18 in General Discussion
So attached you'll see a schematic to trigger a 5V Buzzer via a 555 timer circuit from an SX pin. (Thats what Net27 is).
This seems to work on a breadboard. The reason I'm using the timer is I want to make the buzzer alternate on and off. which I can change R1 and R2 to change the alternation timing. My question is, the datasheet for the 555 seems to lead me to believe I do not need to drive the 555 from a transisitor amplifer to do what i'm doing. Basicly, I'm driving it from the SX. Does this seem right? My buzzer is well under 10ma draw? Does this schematic look right to do this?
R3=10K
Incidently, I had to add D2 as it seemed that when I triggered this circuit without it, it would short the rail supply and reboot the SX? NOt quite sure why but this diode (1N4001) solved it. I'd be curious if anyone has some insight into what was going on here to require this?
Thanks again! Gotta love the SX and parallax!
Post Edited (Chicago Mike) : 3/19/2009 2:25:32 AM GMT
  • UghaUgha Posts: 543
    edited 2009-03-19 01:24
    I'm curious about the 555 interface as well as I'm considering using a 555 for servo pulsing. Please post if you figure it out.
    Have you considered using interrupts on the SX to control your buzzer?
    A 555 has tremendous current spikes during transitions.· You need a really stiff supply, as these can be around 200mA.· A 7555, which is a CMOS device, does not have that unfortunate characteristic.· In either case, especially the former, it's not proper to source the 555's +V from an SX (or Stamp) output.·
    What you're looking for is a gated oscillator, to enable/disable the 555's output.· This can be done by adding a MOSFET to the standard astable circuit (see attached.)
    492 x 397 - 17K
