Yet another Industrial App
This seems to be the week for showing off our industrial apps so here's mine. It's a RF detector with dynamic range of 60 dB and a usable frequency range of 50 MHz to 2 GHz. It is temperature compensated. The interface is IP based and utilizes a XPortAR. I'm also using Power over Ethernet to provide the +3.3V needed by my circuit. Not shown is the custom extrusion it's housed in. I work in the broadcast industry and my device measures the power level of TV & FM signals through transmission line(s) to the antenna. Power levels range from 100 W to 200 KW.
Tom
Tom
Tom
Tom
It shows that there are a lot of lurkers (effectively) on this forum that are doing some serious stuff! BTW, putting aside the technology I also consider 200 kW RF to be some pretty serious stuff
*Peter*
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
3Com® OfficeConnect® Managed Gigabit PoE Switch (3CDSG10PWR)[noparse]/noparse][url=http://www.3com.com/prod/it_IT_EMEA/detail.jsp?tab=features&sku=3CDSG10PWR]ITA[/url [noparse]/noparse][url=http://www.3com.com/products/en_US/detail.jsp?pathtype=purchase&tab=features&sku=3CDSG10PWR]ENG[/url
I am sure because I own two and together with·five "3Com® IntelliJack® Switch NJ220" forms the network structure in my domotic home (multiroom/multimedia, voip, internet, remote video-security and home automation control...)
BTW: the difference between fast-ethernet(100M) and gigabit-ethernet is that the last one utilizes all the RJ45 wires. PoE is a DC power supply above which is superimposed the differential (AC) communication. This can be done on all four twisted pairs as noted on XPortAR datasheet (I also use this beast even if it is not so cheap - next todo: invest some money in their SDK so that I can customize the firmware)
Cheers
www.tdswieter.com
The transformer is a standard made by Coilcraft for PoE. I really hate to think about custom transformers for medium to small size projects so Coilcraft saved the day. The specific model I'm using is a POE30P-33L_. See these links for more info;
http://www.coilcraft.com/prod_poe.cfm
and
http://www.coilcraft.com/poe_ep.cfm
The optoisolator is a PS2911.
200 KW is for mutiple TV xmtrs feeding a combiner and then split into two equal 100 KW signals in 8 inch line feeding a common antenna.
Timothy, I love PoE. It makes power distribution a snap. And yes, it will be able to handle double the maximum power of the original spec soon. You may have to wait a while for switch manufactures to catch up though you could always build your own power insertion device.
dMajo, You're right about the price being high but it was the only device I could find at the time with PoE capability. I could have used a xfmr but the total size was too great.
Tom
