Cheap Accelerometers anyone?
So, I've been wanting to play with some acceleromoters for some time now, but haven't had the chance to do it with school, my other PropBoard project, and other things. Well, I've got time now. [noparse]:D[/noparse]
I got some LIS3LV02DL chips the other day and after 6 chip failures due to some bad solder paste, I've got the chip working, thanks to Tim Moore's object for a simliar chip, the LIS3LV02DQ.
This chip is a 16-bit, triple axis, 3.3V compatible, VERY precise accelerometer. I'm looking at the numbers bouncing around(slightly) on my TV screen and I've got a big grin on my face. This really is an amazing chip, and I have sooo many ideas for it. The only problem is, they are rather pricey. No where near what sparkfun sells them for, but still pricey - about $8 a pop in small quantities. I want to order at least 15 for myself, but the price drop is at quantites of 50 or more. I've made a small PCB for the chip with a mounting hole, and 4 holes for wires. I've got a pretty neat method for soldering these tiny QFN chips, so I can take care of that. Anyone interested in some of these? I think I can get the chip, PCB, and the chip soldered, mailed, etc. for about $12-$15. There are a few other components that I have to solder on the board, but not too much.
My last PropBoard project was a pretty big hassle, and thank you to everyone that bought some. My goal was accomplished, however, in ordering a large quantity and getting the stuff for myself, for dirt cheap. I'm hoping to do the same again, and get you guys some stuff for cheap while I'm at it. [noparse]:)[/noparse]
Just reply or PM me if you want a few
Post Edited (Philldapill) : 3/11/2009 9:51:28 PM GMT
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
If you guys have any suggestions as to what the board layout should be, by all means, suggest. Right now, the board size is about 0.5" x 0.5". Pretty small... Also, the chip itself can be driven with i2c or SPI, BUT the object that Tim Moore wrote, works strictly with an i2c interface. This is why there are only 2 data pins, and 2 power pins. It's simplier and more compact that way.
Again, suggestions are more than welcome. By the way, I played with the chip for a minute after class today... I'm blown away by the sensitivity. I'm wondering if it's actually TOO sensitive. I mean, I have it on the floor, and my foot steps cause the numbers to jump around a bit - that's 3 feet away on carpet!
Earl
BTW, can you do a tutorial on QFN soldering ? I have several IDC gyro chips that are 28 pin QFN. Need a breakout board. You may want to look at this GYRO chip and offer it on a board.
PS. By what means did you send the boards UPS, USPS?
Thanks, Tom Perkins
http://www.schmartboard.com/index.asp?page=products_csp&id=125
Also, how about a 5DOF or 6DOF board. All I have seen are more than $100
3 Acl and 3 gyro would be great with a i2c or spi a/d converter on one board. I am building a quardocopter with a prop board and need some sensors !
Earl
Tom, I sent them out USPS First Class Mail... Using my insane inductive reasoning skills... I assume you didn't get the package yet?(uh oh... PM Me)
SRLM, I'm pretty sure I can get both a good gyro and accel chip wrapped up into a neat little package with a bow on top, for under $40 for sure(unless gyro's are $25 or more... We'll see.)
And guys, don't worry about any commitments yet. I'm just feeling the water to see if this would be a good deal for me and anyone else. I'm going to keep looking for these gyros. In particular, I'm going to try to find one with a spin object already written... unless anyone wants to make one? Anyway, thanks for the responses guys!
http://www.st.com/stonline/stappl/cms/press/news/year2008/p2318.htm
Look at the data sheet on it ! 2000 deg/sec resolution. I think even at $40 the chip is worth it because of the specs. I just dont know if the iron method of putting together this thing would be practical tho. Sparkfun says they may be interested in the design but the lead time is prob at least 6 mo.
See my post on the pcb breakout board that could be used. I think they would layout a board with 4 x 28 pin qfn chips for about $9 each. Right now the $9 board has 4 QFN breakouts. one a 16 pin, one 28 pin a 16 pin and one other.
The ST gyro sounds good for $2.50, and mabey we can talk them out of 50 or so at that price. I am sure we can layout a sub $100 6dof board with i2c a/d and all... Whats everyone think ?
Earl
Breckout board http://www.schmartboard.com/index.asp?page=products_csp&id=125
By the way, IF(and that's a big IF), we can mass-order some of these gyros(lot of 50 or more) we can get the gyro down to $30. When you factor in the accelerometer, pcb, and gyro together on a single pcb, I think I could get these done for about $50. That's a pretty big "I think"... We'll see.
Post Edited (Philldapill) : 3/11/2009 2:46:49 AM GMT
My quadcopter is physically coming together. I have th4 4 brushless motors and ESC's and props, and a 6 ch TX and RX. Prop board and been experimenting with the RX and servos on the prop board.
Earl
One other objective would be to protect the outboard props with some kind of cage. I want this thing as indestructible as I can make it because I have TRIED to fly heli's , even co-axil ones, and I am not too good. My main use will be for pic and video platform. End goal would be one that could take off and land autonomously and fly to gps points remotely and return with at least a 30 min Li-Po battery.
With all the things I want on this puppy, I'll be needing a 25HP outboard boat motor ! I'll show some pics of what I am doing soon. (need to clean up lab a bit first) I also have a 50' x 70' Manufacturing facility here to put something into production. MMMM...Homeland securty funds to get it started ? We are in the middle of New Mexico and have room to fly protos. My place is 1/2 mile by 1/2 mile 160 acers. Nearest neighbor is 2 miles away. Been working on this for several months now and can see a good product to come of this...Cheeper than the x6 tricopter at $14,000. and hopefully with better and more sensors on it. Gnd sevcing radar, ir thermopiles, gyros, accel, dgp barometric pressure for altitude.etc. Lets dream BIG..then scale back just a little !
Earl
My point is, I think that would be awesome to develope something like this and market it. My parents have a similiar building - 30' x 60' and virtually every tool I can think of.(Too bad I live in campus housing now...) I'm thinking about starting this project up and really rolling this summer. By all means, PLEASE post pictures, and ever scrap of progress you make with this thing. Quadrocopters make me act like a little kid on christmas morning.
Earl
The professional ones will be $15 since I'll have to buy the chips and not use my samples...
Post Edited (Philldapill) : 3/11/2009 9:44:28 PM GMT
So, home-brewed boards it is. $5/each for the sample ones I have, and when I run out of those, $15 a breakout board w/ chip and caps soldered. I'll post a picture of the finished board tomorrow when school is over.
A) I have sent you a PM.
What price for such a 6 DOF board or sensor, if 50 were to be bought?
Thank you, Tom Perkins
EDIT: Just FYI to everyone, I'm seeing about 1% jitter on each axis with the LIS3LV02DL chip. I doubt that's much of anything for a kalman filter to take care of... It seems the jitter also decreases in percentage as the acceleration is higher. When I have the thing sitting on my table, the X and Y have a fairly consistant 1% jitter, while the Z axis is more like 0.1% since there is more acceleration on that axis. Just FYI.
Post Edited (Philldapill) : 3/12/2009 12:08:01 AM GMT
well, took my night pills so Im fading...us old guys do that......I remember when 63 was old...now thar im here, its not THAT old
Earl
I'm definitely interested in the accelerometer... regardless of specs. I would like 4, but I would order more. If you only have a couple left, don't re-order for me.
Rich
http://www.freescale.com/files/microcontrollers/doc/data_sheet/MC9S08QE8.pdf?fsrch=1&WT_TYPE=Data Sheets&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
And the 3 axis part
http://www.freescale.com/files/sensors/doc/data_sheet/MMA7260QT.pdf?pspll=1
It also has a rocker ball and 2 push buttons if you want, But I cut the board in half (Cuts electronically very nice). So you end up with a board 1" x 1" with a 3 axis accl that talks to the world via SCL/SDA.
Now to write some code to talk to it !!!Nunchuck wires on the ckt board.....
Red > Pin 3 = VDD (3.3 Volt)
Yellow > Pin 7 = SCL
Green > Pin 8 = SDA
White > Pin 5/6 = Ground
Black > Pin 5/6 Ground Plane (VSS)
Post Edited (earl@uphi.net) : 3/15/2009 3:51:41 AM GMT
Post Edited (earl@uphi.net) : 3/15/2009 5:33:06 AM GMT
