Hydra Expansion Card header spacing for breakout cable
WBA Consulting
Can someone confirm the lead spacing (pitch) of the header locations on the expansion cards that come with the Hydra kit? I am making some breakout cables for my dad and forgot to verify the pitch before I shipped it off. My plan was to solder a header to the card and make a breakout cable that has crimped pins that can be plugged into a breadboard.
Also, how about the pitch of the expansion card connector itself mounted to the Hydra? My other thought was to pull it off and make a small PCB with the original expansion connector and a small breadboard with I/O header.
thanks........
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
thanks........
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
