Hydra Expansion Card header spacing for breakout cable — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,940
edited 2009-03-09 17:02 in Propeller 1
Can someone confirm the lead spacing (pitch) of the header locations on the expansion cards that come with the Hydra kit? I am making some breakout cables for my dad and forgot to verify the pitch before I shipped it off. My plan was to solder a header to the card and make a breakout cable that has crimped pins that can be plugged into a breadboard.
Also, how about the pitch of the expansion card connector itself mounted to the Hydra? My other thought was to pull it off and make a small PCB with the original expansion connector and a small breadboard with I/O header.
thanks........
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
  • mparkmpark Posts: 1,336
    edited 2009-03-08 15:00
    0.1" for both.
    Thanks for the reply. I think I may have a bottom side add-on solution that will work quite nicely. I'll share the results with the forum when I have a working setup.
    Andrew Williams
    WBA Consulting
