I2C problems in SX/B 2.00.16 with use of the uM-FPU V2. But works in SX/B 1.51 — Parallax Forums
Sens-a-DatSens-a-Dat Posts: 44
edited 2009-06-20 05:41 in General Discussion
I am enclosing a SX48 program which simply uses two LEDs and the uM-FPU V2 math coprocessor. The LEDs are being used to help us determine where in the program we are having problems.
We have compiled the program in both the SX/B 2.00.16 and SX/B 1.51.03 compiler versions. And we are unable to have good I2C communications between the SX48 and the math coprocessor utilizing the 2.00.16 compiler.
In the programs we write, we check the returned acknak value from the I2C device to ensure communications is fine. This is where we are noticing wrong values under the new compiler.
To test the theory that the I2C compiled codes v2.00.16 may be the cause of the communication errors, we placed the assembly codes of the I2C commands which we compiled under v1.51.03 I2 into our larger program which was then compiled under 2.00.16. After doing this, the I2C communications with the uM-FPU v2 was fine once again.
Does anyone have any insight on how to remedy this under the newer compiler? Or is this a software issue for us?
Thank you,
Gary
  • BeanBean Posts: 8,129
    edited 2009-03-06 19:13
    I will look into this.
    The I2C commands where changed to allow for clock-stretching, a rarely used feature in I2C. Maybe that is causing the problem.
    I think I have a uM-FPU, but I'll have to find it.
    P.S. You don't need to break your code into pages, the compiler handles that now (even 1.51.03).
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    Post Edited (Bean (Hitt Consulting)) : 3/6/2009 7:27:53 PM GMT
  • JonnyMacJonnyMac Posts: 9,527
    edited 2009-03-06 20:14
    @Sens-a-Dat: You're using old-style SX/B with the new compiler and that may be causing grief. I didn't port your whole program but I've attached new shell with I2C stuff for you to try. FWIW, I've spent this week testing a new product that uses a 24LC512 EEPROM and is coded in SX/B 2.00.16 -- I've had no troubles at all and have verified that things are working as they should by dumping the contents of the EEPROM to a terminal.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-06-17 10:43
    @Bean,
    Has this been resolved?
    Also, according to this piece of compiled code:
      1487  04BD  0CFE        MOV FSR,#__TRISB               ;  I2CRecv SDA_Pin, i2cData, 1
            04BE  0024
      1488  04BF  005F        MODE $0F
      1489  04C0  0C08        MOV __PARAM2,#8
            04C1  0029
      1490  04C2  0440        CLRB IND.2
      1491  04C3  0200        MOV !RB,IND                   ; clock low
            04C4  0006
      1492  04C5  0446        CLRB RB.2
      1493  04C6  0C0A        MOV __PARAM4,#10
            04C7  002B
      1494  04C8  02EB        DJNZ __PARAM4,@$
            04C9  0012 0AC8
      1495  04CB  0540        SETB IND.2
      1496  04CC  0200        MOV !RB,IND                   ; clock high
            04CD  0006
      1497  04CE  0746        JNB RB.2,@$                   ; wait for SCL input high
            04CF  0012 0ACE
      1498  04D1  0C0A        MOV __PARAM4,#10
            04D2  002B
      1499  04D3  02EB        DJNZ __PARAM4,@$
            04D4  0012 0AD3
      1500  04D6  0368        RL __PARAM1
      1501  04D7  0726        MOVB __PARAM1.0,RB.1
            04D8  0408 0626 0508
      1502  04DB  02E9        DJNZ __PARAM2,@$-25
            04DC  0012 0AC2
      1503  04DE  0440        CLRB IND.2
      1504  04DF  0200        MOV !RB,IND
            04E0  0006
      1505  04E1  0446        CLRB RB.2
      1506  04E2  0C0A        MOV __PARAM4,#10
            04E3  002B
      1507  04E4  02EB        DJNZ __PARAM4,@$
            04E5  0012 0AE4
      1508  04E7  0520        SETB IND.1
      1509  04E8  0200        MOV !RB,IND
            04E9  0006
      1510  04EA  0C0A        MOV __PARAM4,#10
            04EB  002B
      1511  04EC  02EB        DJNZ __PARAM4,@$
            04ED  0012 0AEC
      1512  04EF  0540        SETB IND.2
      1513  04F0  0200        MOV !RB,IND
            04F1  0006
      1514  04F2  0746        JNB RB.2,@$
            04F3  0012 0AF2
      1515  04F5  0C0A        MOV __PARAM4,#10
            04F6  002B
      1516  04F7  02EB        DJNZ __PARAM4,@$
            04F8  0012 0AF7
      1517  04FA  0440        CLRB IND.2
      1518  04FB  0200        MOV !RB,IND
            04FC  0006
      1519  04FD  0446        CLRB RB.2
      1520  04FE  0C0A        MOV __PARAM4,#10
            04FF  002B
      1521  0500  02EB        DJNZ __PARAM4,@$
            0501  0012 0B00
      1522  0503  0520        SETB IND.1
      1523  0504  0200        MOV !RB,IND
            0505  0006
      1524  0506  0C0A        MOV __PARAM4,#10
            0507  002B
      1525  0508  02EB        DJNZ __PARAM4,@$
            0509  0012 0B08
      1526  050B  0018        BANK $00
      1527  050C  0208        MOV i2cData,__PARAM1
            050D  003E
    it appears the SCL signal clocks at 200kHz (50 cycles low,·50 cycles high·@20MHz).
    Is there an option to force 100kHz (or even slower)?
    If a I2C device misses the clockpulse due to high speed,
    maybe the line
    · 1497· 04CE· 0746······· JNB RB.2,@$·················· ; wait for SCL·input high
    blocks program execution (wait forever)
    Edit: just remembered I2CSPEED directive.
    I2CSPEED 0.5 forces 100kHz
    regards peter
    Post Edited (Peter Verkaik) : 6/17/2009 11:06:24 AM GMT
    edited 2009-06-17 13:48
    Peter,
    Do you have the uM-FPU chip ? Can you confirm that it doesn't work ?
    Bean.
    edited 2009-06-17 14:24
    No, but I am debugging some code that accesses some eeprom
    (I still wait to get the exact eeprom that is used) and most of
    the time the program stalls. So I will try I2CSPEED first
    once I hear what eeprom is used and checked its datasheet
    regarding timing.
    The code appears to use a 256byte eeprom. Not sure what happens
    if it turns out the actual eeprom has higher capacity (2-byte address).
    I do have a v3.1 umFPU, but that won't do as a test (different cpu).
    regards peter
    edited 2009-06-17 15:10
    Okay, Thanks Peter.
    Be sure to let me know what the cause of the "stall" is, so I can address it.
    Like I said earlier, the I2C code was changed. But if it is causing problems I will change it back. Clock stretching is not a commonly used feature.
    Bean.
  • ZootZoot Posts: 2,227
    edited 2009-06-19 07:42
    Please, please do NOT remove clock stretching. It is part of the I2C spec and IS much more common in peripheral devices than you might think. In fact the LACK of clock-stretching is what forced me to tweak a version of I2C commands before 2.x. Second, clock stretching makes the I2C commands much more compatible with Stamp specs.
    I have had no problems with I2C in 2.x and that's with a wide variety of devices, some use clock-stretching, some do not. The only time I get stalls is when the peripheral "locks" up while the master is waiting for the clock to be released. In the case of the Stamp, there is a master "timeout" on I2C commands so the program moves on if the clock is not released. This would be a nice addition to SX/B, but the WDT can also be used in this context.
    edited 2009-06-19 08:03
    I agree with Zoot. The clockstretching compiles into lines
    JNB SCLPIN,$
    It is easy to turn this into a loop:
    MOV __PARAM4,#I2CTIMEOUT
    :loop
    · JB SCLPIN,@:loopend
    · DJNZ [url=mailto:__PARAM4.@:loop]__PARAM4.@:loop[/url]
    :loopend
    Regarding my debugging: the I2C eeprom used is an Atmel AT24C01B
    operating at 5 Volt. The datasheet specifies 1MHz clock maximum.
    This eeprom is not likely to be the cause for my stalling program.
    When I do find the cause I will report it here if there is an I2C issue.
    regards peter
    edited 2009-06-20 01:46
    Peter Verkaik said...
    JNB SCLPIN,$
    :loop
    JB SCLPIN,@:loopend
    :loopend
    Deja vu. Had this exact same discussion w/Bean et al some months ago. I used a similar code example for timeout as what you posted. I pointed out that many, many peripherals are essentially micro based, and in my experience, I have yet to find a micro based peripheral with hardware I2C that does not use clock stretching.
    However, there is not necessarily enough __PARAM registers to loop for timeout on clock stretching, so it may not be quite that simple. The reason is that depending on the I2CSPEED setting and the clock speed of the SX, more params get used for nested loops to delay time on the IC signals.
    Zoot,
    The delayloops for I2CSPEED are all by themselves and so
    the used __Param become free once a delayloop finishes.
    For the clockstretching, assume 2 bytes, __Param4 and __Param5
    CLR __PARAM4
    CLR __PARAM5
    :loop
    JB SCLPIN,@:loopend······ '2cycles to stay in loop
    DJNZ __PARAM5,@:loop··· '4cycles to stay in loop, 2 cycles to exit param5 loop
    DJNZ __PARAM4,@:loop·· '4 cycles to stay in loop
    :loopend
    Waitloopcycles max = (256*6 + 2)*256 = 393728
    @50MHz that equals 393728/50MHz sec = 7.87 msec
    That really should be enough even for the slowest I2C device.
    In reality the maximum waittime may even be longer due to a running isr.
    regards peter
