BS2 Alarm Clock — Parallax Forums
BS2 Alarm Clock
ShortShort Posts: 26
edited 2009-03-05 02:09 in Robotics
···· Here is the complete source code and schematic for a LCD alarm clock
upon power up the display will display two brackets, pressing button A
will toggle through curent time, curent date, and what·time alarm is set to.
···· To set data remove·and apply·power to reset to brackets or build in a reset switch, once that is done, pressing button B the display will·go to
alarm set, once that is done pressing button B or C respectively for up and down count, then when desired number is reached pressing button A will
store the number, in retrospect at displaying brackets pressing button C
will start you on date and time set.
···· The two things you will have do do in the code if you desire is make a
reset for the alarm or let it sound for one minute,and make it an AM PM
instead of 24 hour.
····· IF YOU ARE GOING TO USE PIN 9 TAKE LOW 9 OUT OF SOURCE
···· The attached picture is of a alarm clock raido I built around this code.
···· I have modified my design . The finished project is attached below
full source code and l·schematic avalable apon request.
Post Edited (Short) : 8/13/2005 7:09:39 PM GMT
  • WhatWhat Posts: 23
    edited 2008-06-17 03:02
    Short i sent you a couple of pm, are you still around here?
    edited 2008-06-17 14:08
    Hello...according to the system, Short was last seen on Sunday, December 04, 2005.
    Chris Savage
    Parallax Tech Support
  • ReyesBurnsReyesBurns Posts: 1
    edited 2009-03-04 22:22
    My friend’s brother is hearing impaired and as his birthday is coming up next week, I thought I could give him a useful gift to help him as he travels often being a salesman. He often complains that he is late for appointments as his present alarm clock does not function well. Do you know of any site from where I can buy a great alarm clock for hearing impaired people?
  • SRLMSRLM Posts: 5,045
    edited 2009-03-04 23:03
  • WardTorresWardTorres Posts: 1
    ShakeAwake Vibrating Alarm clocks are useful for hearing impaired people, heavy sleepers and people who hate jarring sounds. These clocks are battery operated portable alarm clocks with vibrator, loud buzzer alert and a snooze button that wakes up even the deepest sleepers on time. This site: shakeawake will be very helpful for you.
    Post Edited (WardTorres) : 3/5/2009 6:17:49 AM GMT
