BS2 Alarm Clock
···· Here is the complete source code and schematic for a LCD alarm clock
upon power up the display will display two brackets, pressing button A
will toggle through curent time, curent date, and what·time alarm is set to.
···· To set data remove·and apply·power to reset to brackets or build in a reset switch, once that is done, pressing button B the display will·go to
alarm set, once that is done pressing button B or C respectively for up and down count, then when desired number is reached pressing button A will
store the number, in retrospect at displaying brackets pressing button C
will start you on date and time set.
···· The two things you will have do do in the code if you desire is make a
reset for the alarm or let it sound for one minute,and make it an AM PM
instead of 24 hour.
····· IF YOU ARE GOING TO USE PIN 9 TAKE LOW 9 OUT OF SOURCE
···· The attached picture is of a alarm clock raido I built around this code.
···· I have modified my design . The finished project is attached below
full source code and l·schematic avalable apon request.
Post Edited (Short) : 8/13/2005 7:09:39 PM GMT
instead of 24 hour.
http://www.google.com/products?rlz=1C1GGLS_enUS316US316&sourceid=chrome&q=Alarm+Clock+Loud&um=1&ie=UTF-8&ei=AQmvSb_hO4K2sQOgpKWkDg&sa=X&oi=product_result_group&resnum=1&ct=title
Post Edited (WardTorres) : 3/5/2009 6:17:49 AM GMT
