Propeller PockeTerm kit arrives
Dr_Acula
The N8VEM is a great CP/M board but up until now it has needed a terminal program on a PC to run. Not any more - the PockeTerm kit from Briel computers provides a good old-fashioned serial terminal solution and creates a standalone computer that does not need a PC drvernacula.topcities.com/n8vem.htm
This is where the Propeller really shines. The kit arrived today with all the parts and the documentation and took about half an hour to solder up. Not only did it work first time, but the eeprom came already pre-programmed. This was a "solder it up and plug it in" solution and I didn't even need to fire up the PC. Top marks for Vince for making it so easy, and top marks to parallax for designing such a cool chip.
Next step might be to see if that SD socket can't be turned into a disk drive on CP/M. And then start porting bits of the N8VEM into the propeller...
Found it ...http://www.brielcomputers.com/wik/index.php?title=PockeTerm
Kudos for a great finished product! My experimental terminal with PropDOS should run on it,
giving you some limited SD support. (There's a socket on the Pocketerm for uController's SD card.)
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
OBC - You are too modest. Your VT100 code was nearly complete. That was my first time working on code with somebody. I highly recomend working with other people on code like that because when one gets stuck the other is there to find a way.
Vince
hackaday.com/2009/03/04/n8vem-computer-with-a-3km-wireless-link/#comments
This is a great demo of the capabilities of the Propeller.
