LCD Display with SX28
Hey guys,
I'm a total noob when it comes to this stuff. As part of my college course I have to do a project which is making a digital alarm clock using the SX28. We are using a JM162A LCD display. I have the datasheet attached. I was just wondering if anyone has any experience with using an LCD as I have no idea where to start or how I go about displaying anything on it.
Thanks in advance!
Thanks in advance!
1 - Open the SX/B help file by running the SX-Key IDE and clicking Help->SX/B Help.
2 - Click on the section in the help file labeled "Example Projects"
3 - Click on and read "Serial LCD" and "Clock / Timer"
4 - Build both projects so you understand what they are doing and how they do it.
5 - Combine elements from both projects to create your desired project.
If you're a "total noob," then you need to do the work of learning from the examples first. Don't try and build something until you at least understand how others have build working projects, then you can move forward with your project
PeterM
http://search.parallax.com
http://www.electronics-lab.com/articles/lcd/lcd1.pdf
One thing to keep in mind regarding LCDs on this forum is that a lot of forum members use serial LCDs, but the LCD you're using is a parallel display.
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
Main things to keep in mind
1) Timing (particularly for Propeller and SX28). Make sure the E pulse widths and data hold time minimums are kept. It's always safe to go slower than the specification.
2) Make use of the 'busy' status.
I've included the Stamp code here, which you should be able to trivially adapt to SX/B. I didn't have to add wait time for the Stamp because·each command·runs much slower than SX28 will.·This should provide a good leg up to adapt to SX28 to get you going. Let me know if you need additional help.
The project/code was targetted at a younger age crowd introducing them to microcontrollers, so please forgive the over-simplistic comments. I also just·added some notes for porting to SX/B prior to uploading.
[noparse][[/noparse]Edit] Fixed typo in CON section
Post Edited (JonnyMac) : 3/1/2009 11:18:44 PM GMT
Yes CON 1
No CON 1 ' <-- should this be 0?
In light of that, one· way to quickly connect an LCD to the Professional Development Board (PDB) and enable the student to display "Hello World" on the display is to use a "wiring harness".· Jon's program above is an excellent example of a nice clean software design that the student can study also.
Photo 1 shows the PDB with the wiring harness in place (blue CAT5 cable across top and along left).·
Photo 2 shows the 40 x 2 Parallel LCD modules that the college bought from All Electronics for about $6 each.· These had the cable and IDC connector already attached.· The nice thing about them is that you program them the same way as a standard 20x4 parallel module.· The photo also shows the red connector (see photo3) and the punch down tool for the red connectors (the tool is pricy at $21 but you can do the same thing with careful use of a small screwdriver.
Photo 3 is a closeup of the red connector and the strip header pins used to change the red connector from a female connector to a male plug.
Stock #'s
1) PDB,· 28138, $159.99, Parallax
2) LCD,· LCD-60, $5.50, All Electronics
3) Red Connectors, #750881, $0.33, Jameco
4) Punch Down Tool, #365974, $20.89, Jameco
5) .100" Pin Strip Header, 36pin, #517-834-02-36, Mouser
6) Cat 5 cable, local hardware store
ASSEMBLY INSTRUCTIONS:
1) Cut the pin strip header into groups of 8
2) Cut about 12" of Cat5 Cable
3) punch down the wires to the red connector, remember to punch the colors in the same SEQUENCE on both connectors.
4) Insert one end of the cable into RC
5) Insert the second end of the cable into the X2 Connector (upper right on the PDB).· Now here is the tricky part.· The X2 connector is 7 pins wide and the Red Connector is 8 pins wide.· So you need to let one pin hang out.· Notice in photo 4 that the hanging out pin is the one that is connected to RC.0 on the other end.· Also note that the Red Connector is on the OUTSIDE pins of X2 (the inside socket connect to different parts of the LCD).
John J. Couture
San Diego Miramar College
