Interfacing the MAX1270 ADC - Newb SX'er
hey all, im a fairly proficient stamper, and i have finally made the leap to the sx, im still a little overwhelmed, but i thin im wrapping my head around it all.
I am trying to read the max1270 ADC with the following code that doesn't seem to work... has anyone used this chip with the sx before, might you see anything wrong with this code?
thanks to all in advance!
' Device Settings
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "Max1270"
' IO Pins
SClock VAR RA.0 ' shift clock
SIn VAR RA.1 ' shiftin data
Sout VAR RA.2 ' shiftout data
CS1270 var RA.3 ' max1270 chip select
' Variables
ADChan var byte
ADRaw var byte
config var byte
PROGRAM Start
' Subroutine Declarations
GET_ADC SUB 1 ' get value from ADC
' Program Code
Start:
Low sclock
high cs1270
Main:
get_adc 0 ' get adc channel 1
watch adraw 'debug adc
goto main 'loop
' Use: aVar = GET_ADC
' -- reads ADC0831 and places value into 'aVar'
GET_ADC:
ADChan = __Param1
READ AdcCfg + ADchan, config ' read config... maybe
config = %11110000 ' set config t +5chanel 0
low cs1270
SHIFTOUT SOut, SClock, MSBFIRST, config 'set config and channel
High Cs1270
adRaw = 0
low cs1270
SHIFTIN Sin, sClock, MSBPRE, adRaw\12 ' deactivate ADC0831
high cs1270
RETURN ADRaw
AdcCfg:
DATA %11110000, %11100000, %11010000, %11000000, %10110000, %10100000, %10010000, %10000000 ' 0-5
how in sx/b do you handle multiplying a variable by 1.2207?
in stamp basic i would do
mVolts = adcLevel + (adcLevel ** $3880)
thanks!
You could also use */ like this:
...with a little less resolution, but it may be adequate for your needs.
This sx/b is pritty fun. though i did spend a good day thinking my key was broke, till i realized you have to pull the local oscillator in debug mode cant wait to learn all the neat math quirks:>
Be sure to read through the SX/B help file and the "What's New" file for SX/B 2.0.
chlevel = 852 in debug when im expecting like 4_950..
without the math it works ok.
Main: FOR chan = 0 TO 7 chLevel = GET_ADC chan tmpW1 = chLevel ** $3880 chLevel = chLevel + tmpW1 WATCH chan, 8, udec ' use Debug --> Run WATCH chLevel, 12, udec BREAK NEXTdanke very much
Main: FOR chan = 0 TO 7 chLevel = GET_ADC chan tmpW1 = chLevel ** $3880 mvolts = chLevel + tmpW1 WATCH chan, 8, udec ' use Debug --> Run WATCH chLevel, 12, udec watch mvolts,12, udec BREAK NEXT GOTO Maindebug results
chan = 8
chlevel= 4_054
mvolts= 852
