Interfacing the MAX1270 ADC - Newb SX'er — Parallax Forums
skynuggetskynugget Posts: 172
edited 2009-03-02 21:15 in General Discussion
hey all, im a fairly proficient stamper, and i have finally made the leap to the sx, im still a little overwhelmed, but i thin im wrapping my head around it all.
I am trying to read the max1270 ADC with the following code that doesn't seem to work... has anyone used this chip with the sx before, might you see anything wrong with this code?
' Device Settings
DEVICE          SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ            4_000_000
ID        "Max1270"
' IO Pins
SClock          VAR     RA.0                    ' shift clock
SIn                VAR     RA.1                    ' shiftin data
Sout        VAR     RA.2                    ' shiftout data
CS1270        var    RA.3            ' max1270 chip select
' Variables
ADChan        var    byte
ADRaw        var    byte
config        var    byte
  PROGRAM Start
' Subroutine Declarations
GET_ADC     SUB    1                         ' get value from ADC
' Program Code
Start:
      Low sclock
    high cs1270
Main:
      get_adc 0             ' get adc channel 1
    watch adraw            'debug adc
    goto main            'loop
' Use: aVar = GET_ADC
' -- reads ADC0831 and places value into 'aVar'
GET_ADC:
    ADChan = __Param1
      READ AdcCfg + ADchan, config     ' read config... maybe
    config = %11110000     ' set config t +5chanel 0
    low cs1270
    SHIFTOUT SOut, SClock, MSBFIRST, config     'set config and channel
    High Cs1270
    adRaw = 0
      low cs1270
    SHIFTIN Sin, sClock, MSBPRE, adRaw\12                                                      ' deactivate ADC0831
      high cs1270
    RETURN ADRaw
AdcCfg:
    DATA    %11110000, %11100000, %11010000, %11000000, %10110000, %10100000, %10010000, %10000000 ' 0-5
thanks to all in advance!
  • JonnyMacJonnyMac Posts: 9,558
    edited 2009-02-28 16:21
    You're using an older style of SX/B syntax that doesn't allow you to return a word (subs can only return a byte). I've updated your code -- give this a shot.
  • skynuggetskynugget Posts: 172
    edited 2009-03-01 12:24
    hey thanks for your help jonnymac, i appreciate the comments in your source. hop.gif
    edited 2009-03-01 22:16
    hey another silly question
    how in sx/b do you handle multiplying a variable by 1.2207?
    in stamp basic i would do
    mVolts = adcLevel + (adcLevel ** $3880)
    thanks!
    edited 2009-03-01 23:11
    You can do the same thing (**) in SX/B, but you'll have to break that compound expression into simpler lines:
    tmpW1 = adcLevel ** $3880
    mVolts = adcLevel + tmpW1
    You could also use */ like this:
    mVolts = adcLevel */ $0138
    ...with a little less resolution, but it may be adequate for your needs.
    edited 2009-03-01 23:59
    thanks again jonny, hope i can return the favor some day.
    This sx/b is pritty fun. though i did spend a good day thinking my key was broke, till i realized you have to pull the local oscillator in debug mode cant wait to learn all the neat math quirks:>
    edited 2009-03-02 00:36
    SX/B was designed with BASIC Stamp users in mind; many of the things you've done in the past with BASIC Stamps have analogs in the SX. Though some aspects require a bit more effort, it's worth it. Having the ability to add "virtual peripherals" to a project using the SX's speed is really a lot of fun.
    Be sure to read through the SX/B help file and the "What's New" file for SX/B 2.0.
    edited 2009-03-02 05:14
    hey jonnnymac, does this look right to you...
    chlevel = 852 in debug when im expecting like 4_950..
    without the math it works ok.
    Main:
      FOR chan = 0 TO 7
        chLevel = GET_ADC chan
        tmpW1 = chLevel ** $3880
        chLevel = chLevel + tmpW1
        WATCH chan, 8, udec                ' use Debug --> Run
        WATCH chLevel, 12, udec
        BREAK
      NEXT
    danke very much
    edited 2009-03-02 05:16
    You should add another variable so that you can see what the raw input is versus the final calculated value. Your raw input should be from $000 to $FFF.
    edited 2009-03-02 19:38
    like this?
    Main:
      FOR chan = 0 TO 7
        mvolts = chLevel + tmpW1
        watch mvolts,12, udec
        BREAK
      NEXT
      GOTO Main
    debug results
    chan = 8
    chlevel= 4_054
    mvolts= 852
    edited 2009-03-02 20:33
    See attached.
    duh, watch 16 bits! thanks man , really appreciate it.
