eb500 bluetooth
Hi, i'm not sure which forum to post this in, but i just received an eb500 bluetooth module yesterday. I hooked it up and my computer detects it just fine. As of yet i have not tried to program it at all, but when i try to connect it, everything goes swimmingly, but then after i click ok on my bluetooth window, if i go back into it, the device is gone and the computer has no recolection of it ever being there. Does anybody have any advice?
Russ
Russ
Dave
Dave Andreae
Parallax Tech Support·
Dave
Dave Andreae
Post Edited (Dave Andreae (Parallax)) : 2/27/2009 5:39:17 PM GMT
The problem with power supplies can happen when you’re using an unregulated supply on such boards as the Board of Education where the voltage from your power supply is fed directly into the EB500. The EB500 can’t handle more than 12V max on its VIN pin. However in your circuit you are powering it from a regulated 5V source which is completely fine. I’m glad to see your connection issue was not related to power. Take care.
Chris Savage
Parallax Engineering
