Propeller and Wifi - Page 2 — Parallax Forums
Propeller and Wifi
2»
  • RaymanRayman Posts: 15,891
    edited 2009-02-25 21:39
    James, very sorry for the confusion! I don't always have the time to follow these threads as carefully as I'd like...
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-02-26 00:34
    Fire up the computin' machines!
    JMH
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2009-02-26 01:35
    What's the application?
    I've tested with WiFi serial port emulators on mobile devices and it's not pretty.
    Jim-
    Signature space for rent, only $1.
    Send cash and signature to CannibalRobotics.
    edited 2009-02-26 03:21
    HTTP is not the only protocol. FTP, UDP etc. are fine for robotics. WiFi hotspots are available in large cities for free. I want to create a mini device that can monitor human vitals and link to a hospital. Also, I want to do it for the sheer aggrivation of it. Also, these devices are free from USB enumeration issues. If the project is a failure, I still learned valuable knowledge and experience.
    This is another solution a belatedly ran across www.sparkfun.com/commerce/product_info.php?products_id=8869
    No fancy surface-mount tomfoolery to wank about. Totally self-contained solution.
    Chuck, I live in Austin - taxes are no fun but cheap, fast delivery is.
    JMH
    Post Edited (James Michael Huselton) : 2/26/2009 3:55:11 AM GMT
  • Chuck RiceChuck Rice Posts: 210
    edited 2009-02-26 04:44
    It appears that you can solder to the connector. I have not powered it, but I now have 6 pigtails soldered on to the connector (pins 1 thru 6).
    I took a piece of 22 gauge stranded wire (it had 7 strands) and attached one strand to each of the surface mount legs of the connector. It took several tries. The connections to the surface mount pins are rather delicate and can move, so to keep them sound and prevent them from shorting, I mixed up a small amount of epoxy and covered the joints.
    A circuit board would be better, but this was an interesting challenge. I did find a SchmartBoard
    Mouser Part #:    872-202-0007-01
    Manufacturer Part #:    202-0007-01
    Manufacturer:    SchmartBoard
    Description:    SO/SOP Packages SO .5mm putch
    at Mouser that I think would work, but it is rather large. I might get one my next order and see if it would work out better. Has anyone tried a SchmartBoard? Do they work?
    Attached is a picture (thru a magnifying glass) of the result. I should be able to tie those pigtail wires to a row of headers, then add more epoxy to protect the pigtails. This is a major hardware Kludge, but it should allow me to test. (I hope).
    Post Edited (Chuck Rice) : 2/26/2009 1:07:50 PM GMT
    600 x 800 - 112K
  • jazzedjazzed Posts: 11,803
    edited 2009-02-26 05:27
    Spidey! [noparse]:)[/noparse] Hmm. Wonder what the demand would be for a convenient package.
    --Steve
    edited 2009-02-26 19:03
    I decided to order the sparkfun module - www.sparkfun.com/commerce/product_info.php?products_id=8869.
    This way, Chuck and I have two different attack angles. One way or another, this project will succeed!.
    JMH
    edited 2009-02-26 19:44
    James Michael Huselton said...
    I am on my own now, eh? [noparse]:)[/noparse]
    That module looks to be much easier to interface to hardware wise. It will be interesting to see what can be done with it. Maybe we can mask the differences with a wrapper object so that the propeller user can use either with common API calls.
  • CraigMCraigM Posts: 2
    edited 2009-02-26 21:19
    A few months ago, I successfully integrated the Roving Networks RN-111b and ConnectBlue OWSPA311g wifi modules to the Propeller. They are both similar and fairly straightforward serial interfaces. I integrated a SC16IS760 over SPI to the propeller to provide a UART capable of 1.3mbit serial and both modules will handle this rate. However, their actual network speeds are quite limited. Offhand, I can remember the Roving Networks module to be something around 48kbytes/sec over TCP and I think I remember the ConnectBlue module to be slightly faster. My employer owns the code I wrote, but I should be able to answer questions regarding them.
    There are some other interesting modules out there that I would like to try. G2 Microsystems just got FCC approval for their G2M5477 module and it promises to have a much higher throughput than the other two, including an SPI interface. I hope to have one in my hands soon.
    -Craig
    edited 2009-02-26 23:46
    Chuck,
    I want this to be an open source research project. I have no intention of leaving you on your own, Let's pool our experience and code to create a solution that solves for the hardware-specific case, and a driver that solves a more generalized case. Ultimately, this can be more useful to the forum members, especially if it is well-documented and provides a base to further expand upon. Everyone has talents and technical abilities that can, if well-documented and structured, can be a fun basis for everyone to contribute.
    JMH
    edited 2009-02-26 23:51
    I have dozens of SchmartBoards. They are extremely easy to solder, as they have a patented process for hand-solder flow that virtually precludes bridging and need for solder wick. Been using them for the tiniest pitch lead spacing and it works every time.
    JMH
    edited 2009-02-26 23:55
    CraigM,
    JMH
    edited 2009-02-27 02:02
    I dropped by ACE Electronics in Houston today and they had the SchmartBoards. I soldered the second connector I had onto the SchmartBoard. It LOOKS a lot better, but it was still pretty difficult to solder. 0.5 mm is pretty small. It is easy to get a solder bridge or a cold joint on one of the 30 pins when they are this small, no matter what you do. Were you using the EZ version or the original version. I got the non-EZ SchmartBoard. That may be why I got some bridges. I am going thru the pins one by one with my OhmMeter and have found a couple of shorts so far. I picked at the pins with an Exacto blade to find pins that did not get soldered. Too bad I do not have an X-Ray! [noparse]:)[/noparse]
    I hope to be ready for a smoke-test soon.
    edited 2009-02-27 05:32
    I always use the EZ versions. That's why they are faultless.
    JMH
    edited 2009-02-27 14:54
    Not to throw another iron in the fire because it looks like you are pursuing some good products already, but did you consider this module from Wiznet? www.wiznet.co.kr/en/pro02.php?&page=1&num=180 I have used the wired W5100 and I am working on a project to use the W5300 and I liked those products, so maybe the wi-fi solution is also good. Your thoughts?
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
    www.tdswieter.com
    edited 2009-02-27 15:09
    The reason we didn't try the WIZnet module was because it does not have FCC modular approval. You should be able to use it for hobby work, but not in any commercial product without paying for your own FCC compliance testing.
    edited 2009-02-27 18:20
    Again, pursuing many parallel lines of development will maximize the chance of success.
    JMH
    edited 2009-02-27 23:45
    Thanks for pointing that out. I didn't realize the lack of FCC. I just talked with the Wiznet team at a show yesterday and had I realized this I would have inquired.
    www.tdswieter.com
    edited 2009-02-28 02:10
    Tim,
    A bit off-topic. I purchased some of your warm white Lumen lighting strips. What is the current draw per strip at 12v?
    JMH
    edited 2009-03-16 14:56
    Any news from the WiFi front?
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-03-21 03:34
    I can order the module that I originally intended - next week. My budget for last month ran out.
    JMH
    Post Edited (James Michael Huselton) : 3/21/2009 4:30:34 AM GMT
  • BradCBradC Posts: 2,601
    edited 2009-11-30 16:32
    Any news?
    Have you in fact got any cheese here at all?
    If you always do what you always did, you always get what you always got.
    edited 2009-11-30 16:59
    Yes. The module is sitting on my bench. Had another stroke scare, but it resolved itself.
    But my progress has been slow, due to my health. I was clinically dead, but i'm feeling much better now. yeah.gif
    JMH
    edited 2009-11-30 20:23
    I wish there were a cheaper option out there... I was looking around again today... The WiFly GSX RN-131C looks pretty reasonable.
    I see it for $49 and the documentation seems to make sense to me...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2009-11-30 21:08
    Rayman,
    I have the exact same module sitting on my bench!
    Where, praytell, do you se it for less then $50.00?
    JMH
    edited 2009-11-30 23:26
    Order direct here:
    http://www.rovingnetworks.com/pricing.php
    Or here:
    http://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=43979
