Debug/Terminal question
Hello guys,
I have a quite simple question yet, it will save me from a lot of troubles....
When I want to type something to the hyper terminal (I use Terminal v1.9b for data logging)
and I want to change line and/or clear screen.... what is the ASCII command I must use....
Is the BS2 debug commands working??? And if yes.... what is the hex equal of them????
This is what I really care for... Cause I'll be making a datalogger and
I need to compare the efficiency of some microcontroller and/or boards...
I need to clear the screen and use some other ASCII commands... but I need to know their HEX form....
I have founded this but does seem to help a lot...
http://en.wikipedia.org/wiki/ANSI_escape_sequences
Thanks in advance,
Lefteris, Greece
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
Thanks in advance,
Lefteris, Greece
-Rule your Destiny-
But it was a compiler parameter......
Thanks for the interest!!!
Lefteris, Greece
Rule your destiny.... Be Good.... Be Bad.... Be Tricky!!!
LiPo.... Nice batteries, but hard to use?
No prob...
www.societyofrobots.com/member_tutorials/node/302
