Debug/Terminal question — Parallax Forums
Tricky NekroTricky Nekro Posts: 218
edited 2009-02-24 23:36 in General Discussion
Hello guys,
I have a quite simple question yet, it will save me from a lot of troubles....
When I want to type something to the hyper terminal (I use Terminal v1.9b for data logging)
and I want to change line and/or clear screen.... what is the ASCII command I must use....
Is the BS2 debug commands working??? And if yes.... what is the hex equal of them????
This is what I really care for... Cause I'll be making a datalogger and
I need to compare the efficiency of some microcontroller and/or boards...
I need to clear the screen and use some other ASCII commands... but I need to know their HEX form....
I have founded this but does seem to help a lot...
http://en.wikipedia.org/wiki/ANSI_escape_sequences
Thanks in advance,
Lefteris, Greece
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
  • JomsJoms Posts: 279
    edited 2009-02-24 22:32
    I don't know if this is what you are looking for or not, but I use this chart A LOT when programming the stamp using serial in and out commands.· It shows the dec, hex, oct, and characters.· It is attached as a PDF.
  • Tricky NekroTricky Nekro Posts: 218
    That was neat, really!!!
    But it was a compiler parameter...... tongue.gif......
    Thanks for the interest!!!
    Lefteris, Greece
    Rule your destiny.... Be Good.... Be Bad.... Be Tricky!!!
    LiPo.... Nice batteries, but hard to use?
    No prob...
    www.societyofrobots.com/member_tutorials/node/302
