Put in SX/B 2.0
So far I absolutely love 2.0. I just have a minor problem I can't be sure of.
I understand that this works:
temp1 var byte
temp2 var byte
temp3 var byte
array var byte(3)
temp1 = 5
temp2 = 10
temp3 = 15
put array, temp1 to temp3
But I had expected put to also work in copying arrays.
Example:
array1 var byte(10)
array2 var byte(5)
i var byte
for i = 0 to 9
array1(i) = i
next
put array2, array1(0) TO array1(4)
But it doesn't work for me... it just overwrites the first byte of array2 with $00
I think I understand that using an array's label is the same as using the first element of the array (array2 = array2(0)) in this case,
but how would I go about doing the above?
I can do a work-around with two counters and a for loop, but I love put so much that I'd like to use that if its possible.
Sorry if this is answered elsewhere or has a simple answer... I·just don't get it.
temp1 var byte
temp2 var byte
temp3 var byte
array var byte(3)
temp1 = 5
temp2 = 10
temp3 = 15
Example:
array1 var byte(10)
array2 var byte(5)
i var byte
for i = 0 to 9
array1(i) = i
next
732 010A 0CDA MOV FSR,#array2 ;put array2, array1(0) TO array1(4) 010B 0024 733 010C 0204 MOV __PARAM1,FSR 010D 0028 734 010E 0CD0 MOV FSR,#array1+0 010F 0024 735 0110 0204 SUB __PARAM1,FSR 0111 00A8 736 0112 0C05 MOV __PARAM2,#(array1+4 - array1+0)+1 0113 0029 737 0114 0200 MOV __PARAM3,IND 0115 002A 738 0116 0208 ADD FSR,__PARAM1 0117 01E4 739 0118 020A MOV IND,__PARAM3 0119 0020 740 011A 00C8 MOV W,--__PARAM1 741 011B 00A4 SUB FSR,W 742 011C 02E9 DJNZ __PARAM2,@$-8 011D 0010 0B14 743 011F 0018 BANK $00Looks to me it should work.
regards peter
I apologize for wasting your time.
